  1. Hi all i have a lot of movie clips and want to name them all give each 1 a title, is there anyway of naming all the movies in 1 go like a batch so as to not do each 1 at a time
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    try mp3tag - its listed in the tools section - but just click on the word itself in my post - the link will take you there.
    It says it can do movie files too.
    There should be a bunch of others out there too. But just watch where you get them from and do a virus check if you get them from some run of the mill website.
  3. Member Budman1's Avatar
    Jul 2012
    NORTHWEST ILLINOIS, USA
    Bulk Renamer Utility is a great tool with any option you would like. The best part is you select the file(s) you want to change and it dynamically changes as a preview before you actually change them.
Name:	ScreenHunter_08 May. 19 23.14.jpg
  4. thanks all to replies where do I find that Bulk Renamer Utility
  5. Member Budman1's Avatar
    Jul 2012
    http://www.bulkrenameutility.co.uk/Main_Intro.php . Download link is on the left of the browser. Or Google it and it's the First entries LOL
Name:	ScreenHunter_08 May. 20 12.02.jpg
    May 2013
    Turkey
    [Attachment 17988 - Click to enlarge]
    This program GUI is most confused. I suggest you use Metamorphose.
    http://file-folder-ren.sourceforge.net/
  7. Member Verify's Avatar
    Oct 2008
    Total Commander has a very flexible bulk file rename facility: Files/Multi Rename Tool (or: Ctrl+M), just google Total Commander.
    Andrew Jackson: "It's a poor mind that can only think of one way to spell a word."
