I want to reprocess a x264 encoded video that I made with virtualdub, but virtualdub only sees the video as slanted grayscale video in the "input video" panel, so the output video is exactly what virtualdub sees. how do I solve this problem? I remember x26e encoder had this virtualdub hack so that virtualdub could use the encoder, I wonder if that's what causes virtualdub to not be able to read x264 videos made by it.
Results 1 to 9 of 9
muffinman123Guest
VirtualDub doesn't decode h.264. A VFW (or maybe DirectShow, depending on how the video is getting into VitualDub) installed decoder does. The VirtualDub hack has nothing to do with your problem. The problem is the decoder used to decompress the video isn't handling the source properly. Probably because it doesn't support the frame size (mod2?).
What is your source file? And how are you getting it into VirtualDub (what source filter? Avisynth?)? -
I can't understand why people use such a bacwarld software as the virtualdub...
ffdshow is normally configured via Start -> All Programs -> ffdshow -> VFW Configuration, or Start -> All Programs -> ffddshow -> Video Decoder Configuration, depending on which VirtualDub source filter you are using (VFW or DirectShow). If you have the Tray Icon feature enabled ffdshow will appear in the Tray when in use and you can configure it from there. I don't know how this works in Wine though.
VP8/Vobris Video not opening properly in VirtualDub?
By RedPenguin in forum Video ConversionReplies: 2Last Post: 13th May 2012, 19:41 -
virtualdub and h264-no error
By uglijimus in forum Video ConversionReplies: 14Last Post: 13th Jan 2011, 22:04 -
help with Getting H264 into Virtualdub v1.9.9
By dnmnbg in forum Newbie / General discussionsReplies: 2Last Post: 1st Jul 2010, 18:43 -
VirtualDub doesn't decode H264/AVC (MP4/M4V)
By klischee in forum Video ConversionReplies: 4Last Post: 3rd Mar 2010, 09:58 -
VirtualDub cannot properly load H.264 Lossless video from AVI or Avisynth
By Jedi787Plus in forum Video ConversionReplies: 1Last Post: 14th Oct 2009, 22:38
