Vidcoder just downloaded an update so I installed it. Now it fails on all dvds I try to convert.
Here is a log of the fail
# Starting queue
## VidCoder 1.4.20.0 (x86)
# Starting job 1/1
# Path: J:\
# Title: 1
# Range: All
# Worker ready: Service state is Opened on pipe VidCoderWorker.4b141ab6-6828-4c92-a647-b554af51da5e
# Connecting to process 6948 on pipe VidCoderWorker.4b141ab6-6828-4c92-a647-b554af51da5e
# Connection to worker failed after 10 retries. Unable to find endpoint.
# Encode failed.
# Job completed
# Queue completed
any idea of what is wrong?
You could post an "issue" over at http://vidcoder.codeplex.com/workitem/list/basic
Until then use vidcoder 1.4.19 beta. https://www.videohelp.com/tools/VidCoder/old-versions#download
Or try download again and reinstall it completely. -
After googleing forever I figured it out. Have to go into settings and then advanced. Then uncheck the box "use worker process to encode" seems to work after that
Thanks for posting the solution. But maybe you should post an issue anyway...it doesn't sound good if you have to uncheck something to get it working.
Problem with updated version of VidCoder
By KyleMadrid in forum Newbie / General discussionsReplies: 7Last Post: 25th Mar 2013, 23:31 -
Vidcoder no longer creates playable mp4's from Bluray? (VLC or anything)?
By David Ross in forum Blu-ray RippingReplies: 17Last Post: 6th May 2012, 04:27 -
TMPGEnc Authoring Works 4 updated with WTV input support
By gyoshi in forum Latest Video NewsReplies: 0Last Post: 4th Mar 2010, 12:05 -
Just updated to IE8 now,Musicmatch jukebox no longer works. Free Alternate
By Denvers Dawgs in forum ComputerReplies: 51Last Post: 11th Feb 2010, 15:52 -
AC3 no longer works w/ WMP 11
By dmjerbear in forum AudioReplies: 2Last Post: 5th May 2009, 22:14
