success / resolved
now normaly, i use windows explorer to open/view the contents, but some files won't open. is there any small utility or command line utility that i can d/l and view them ?
i recieved a cd with latest software and i want to open and view it to see if it has an h264 .ax file in it.
windows xp home.
thank you.
Results 1 to 9 of 9
7-Zip and WinRAR can open most .CAB files.
As a last resort, there is the Universal Extractor:
http://legroom.net/software/uniextract
OT notice:
--- its UPX engine and its Inno Setup Unpacker are outdated, so you'll have to update them manually.
Originally posted by Wikipedia
The .cab filename extension is also used by other installer programs (e.g. InstallShield) for their own proprietary archiving formats. InstallShield uses zlib for compression (see Deflate), but their headers are not the same as for Microsoft CAB files so they are incompatible and cannot be manipulated or edited with the programs that are made for standard Cabinet format. Specialized third-party utilities, such as Unshield, can extract this specific proprietary format.Last edited by El Heggunte; 18th May 2013 at 20:11.
thanks, i d/l 'ed and installed. but man, its very slow. i just want to view the contents but it seems it only extracts. almost 10 minutes and only 1/3 the way through. its slowwwwww
How big are those files?
Also, are you sure there isn't any interfering process running in the background?
AFAIK, the only really-slow "module" of UniExtract is the MHT unpacker.Last edited by El Heggunte; 18th May 2013 at 20:45.
success / resolved
yep, smsystemanalyzer.exe was running, takes 50% in addition to whats running. i 4got to disable that. oh well. anyway, the file was 166mb. i didn't realize that it recreates the folder structures. at least it works, and i found another .ax file to try. ty for helping.
ps: if you ever come across a command line version of a cab reader/viewer, let me know, since all i really want to do most of the time is search for a file.Last edited by vhelp; 18th May 2013 at 21:45.
http://www.softpedia.com/get/Compression-tools/Microsoft-Cabinet-Extraction-Tool.shtml
Not tried it but it might be useful to you. -
Not useful at all. The problematic .CAB files are not the standard ones, but the ones used by InstallShield.
Also, what the heck, a 0.98MB extract.msi wrapped in a compressed .EXE, and the only important part of the MSI package is a 90.2kB extract.exe ?
http://denisbider.blogspot.com.br/2009/06/windows-installer-sucks.htmlLast edited by El Heggunte; 19th May 2013 at 06:58. Reason: add PROOF
ok, so i'm cleaning some space off my hdd. and comming across this file, thought i'd ask one more sort of related question.
what utility can i d/l that will open these .msi files ?
when i d/l files i always label them but sometimes i'm rushing and forget. anyway. the original file was extract_setup.exe and when i 7z to open it, (i use it mainly to see contents of most files) it gave me this "extract.msi" file. i want to see the what files are inside to determine what it was i d/l'ed and if i need to delete the source file.
edit: i got it.. you 1 open in 7z -> 2 open inside -> 3 select cab files or other archive -> 4 open inside, ...
it works so far.Last edited by vhelp; 19th May 2013 at 11:43.
Option 1)
UniExtract ( again)
Option 2)Howto: extract files from a .msi file using the Windows command line
Keep in mind that the file/folder names listed by 7-Zip not always match the actual file/folder names inside the archive
how do i reconfigure default view in open dialog view to details ?
By vhelp in forum ComputerReplies: 11Last Post: 9th Nov 2012, 22:12 -
Flash Drive Contents -- Remote View of PDFs, Quciktime, etc?
By M Bruner in forum ComputerReplies: 5Last Post: 23rd Aug 2009, 02:44 -
How do you change the default View Setting for a folder's contents in Windo
By videopoo in forum Newbie / General discussionsReplies: 3Last Post: 22nd Feb 2009, 17:41 -
Is it possible to change the default "Open" view?
By SLK001 in forum ComputerReplies: 5Last Post: 22nd Oct 2008, 11:38 -
NERO can not keep a Data CD Open- no multisession
By src2206 in forum ComputerReplies: 4Last Post: 19th Aug 2008, 14:23
