Using Vitrual PC, I am wondering what encoding(multiplexing) program works the best. I've heard of TMPGEnc and Nero. My encoding machine will be a G4 400mhz. I am trying not to have to buy a dedicated PC machine just for encoding, but want to know if using VPC is worth it or not. How much RAM should be allocated to VPC, for encoding purposes, and also what should my hard drive image be sized at. Prior to reading that multiplexing could not be done on a Mac(without VPC) I went through many CDR's. At least they're cheap.
Any comments appreciated.
again and again, the best method is to use TMpgenc to encode MPG2 (using the SVCD template), then use VCDImagerGUI to convert that MPG2 to .bin/.cue, finally use Fireburner to chunk that .bin/.cue into two XA tracks you can burn with Toast Multitrack XA mode.
Tried using this method, but in VPC, the VCDimagerGUI kept giving me errors, although I was able to successfully convert the AVI to SVCD using the template.
Are there any updates, specially for windows 98, that might cause VCDimager to work or not?
Randy
<font size=-1>[ This Message was edited by: rsilvaman on 2001-08-02 11:58:08 ]</font>
<font size=-1>[ This Message was edited by: rsilvaman on 2001-08-02 11:58:59 ]</font>
Virtual Sets
By chammond in forum Newbie / General discussionsReplies: 1Last Post: 22nd Feb 2012, 10:24 -
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 13:48 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 15:36 -
Virtual Camera
By Ironballs in forum ComputerReplies: 2Last Post: 25th Jan 2008, 10:42 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 06:18
