I choose a song and I picture for the background, then save the video to my computer and it works fine.
Then, I upload it on youtube and the picture (chosed as the background) appears for only 1 sec.
and then turns to black. The song still playing, though. What I'm doing wrong?
http://www.youtube.com/watch?v=Lox8uQGDz4s
Did you set the duration of the picture display to the same length (of time) as your music track?
Yes, I did.
What I want to do is so simple and can't find an apropriate software for this.
Vegas would render only the first 5 seconds;
Cyberlink Power Director makes a 700mb AVI file and has limited output format;
Windows Movie Maker doesn't support FLAC formats;
and now this...Last edited by titothetitan; 17th May 2013 at 21:04.
Very strange. The only thing I can think of is that the FLAC audio is confusing Youtube's converter (but I doubt it).
https://support.google.com/youtube/bin/static.py?hl=en&page=ts.cs&ts=2888402
Try using WAV instead of FLAC. If you convert to MP4 then try using AAC.
I know you want to use FLAC but some things in life just aren't possible.
VideoPad Editor won't capture from Panasonic camcorder
By dbmcinnis in forum Capturing and VCRReplies: 2Last Post: 1st Sep 2012, 12:58 -
HELP! Black screen/Blue Screen problem
By will7370 in forum ComputerReplies: 2Last Post: 1st Apr 2012, 09:30 -
Turns black and white
By dadihawks in forum Newbie / General discussionsReplies: 1Last Post: 1st Oct 2011, 05:59 -
VideoPad Video Editor narration/media problems *PLEASE HELP*
By 19tyler19 in forum EditingReplies: 1Last Post: 25th May 2011, 01:04 -
black in picture turns green
By heticu in forum Newbie / General discussionsReplies: 2Last Post: 21st Jan 2009, 13:51
