Hi Everybody
I got Big Problems getting my .264 AVC 1080p 29,970 fps (Progressive) File from HD-DVD (with Pulldown flags) to 23,976 fps with removing the Pulldown
> Mediainfo Shows 1080p 29,970 fps Progressive
> VLC Shows 59,940 fps (??)
I've Tried tsMuxer so far by changing the FPS to 23,976 and Remove Pulldown Option but this occurs in the following Errors:
^^The whole Movie all the Time. After finishing the result is smooth Playback of Video but Audio gets async right from the Beginning and it doesn't matter if i correct the Audio delay the Movie will get async at a later time anyway > so no real Solution by just correcting the Audio DelayWarning! Source stream contain irregular pulldown marks. Mistiming between original fps and fps/1.25(without pulldown) exceed 100ms.
Warning! Source stream contain irregular pulldown marks. Mistiming between original fps and fps/1.25(without pulldown) exceed 200ms.
Warning! Source stream contain irregular pulldown marks. Mistiming between original fps and fps/1.25(without pulldown) exceed 400ms.
and so on ....![]()
Please Help me, Thanks in advance.
Closed Thread
Please don't cross post in several forums! Continue in https://forum.videohelp.com/threads/356058-Errors-Removing-Pulldown-Flags-264-AVC-1080p...18#post2241618
Errors Removing Pulldown Flags .264 AVC 1080p 29,970 to 23,976 [SOLVED]
By Logitex in forum Video ConversionReplies: 23Last Post: 19th Jul 2017, 07:52 -
Handbrake Lowering FPS issue (29.970 to 23.976) - Should I be concerned?
By kingaddi in forum DVD RippingReplies: 20Last Post: 3rd Sep 2012, 01:16 -
Honoring Pulldown Flags
By unclescoob in forum DVD RippingReplies: 10Last Post: 26th Jul 2012, 10:14 -
Remove pulldown? (29.97 -> 23.976)
By Asterra in forum Newbie / General discussionsReplies: 2Last Post: 5th May 2010, 20:12 -
Sync 29.970 FPS audio to 23.976 FPS video?
By LCO1971 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 16:23
