Hi Everybody
I got Big Problems getting my .264 AVC 1080p 29,970 fps (Progressive) File from HD-DVD (with Pulldown flags) to 23,976 fps with removing the Pulldown
> Mediainfo Shows 1080p 29,970 fps Progressive
> VLC Shows 59,940 fps (??)
I've Tried tsMuxer so far by changing the FPS to 23,976 and Remove Pulldown Option but this occurs in the following Errors:
^^The whole Movie all the Time. After finishing the result is smooth Playback of Video but Audio gets async right from the Beginning and it doesn't matter if i correct the Audio delay the Movie will get async at a later time anyway > so no real Solution by just correcting the Audio DelayWarning! Source stream contain irregular pulldown marks. Mistiming between original fps and fps/1.25(without pulldown) exceed 100ms.
Warning! Source stream contain irregular pulldown marks. Mistiming between original fps and fps/1.25(without pulldown) exceed 200ms.
Warning! Source stream contain irregular pulldown marks. Mistiming between original fps and fps/1.25(without pulldown) exceed 400ms.
and so on ....![]()
Please Help me, Thanks in advance.
Results 1 to 24 of 24
If it's really progressive 29.97fps then there are no pulldown flags. Please post a sample. 5 seconds with steady movement will be plenty.
Hi manono
Here is a short Sample Clip:
http://www.sendspace.com/file/8vomyc
http://www.sendspace.com/file/gu705d
(Sample splitted in 2 .rar Parts > just extract with WinRar)
If i just Change the Video FPS from 29,970 to 23,976 without Pulldown i get jerky Playback too
I have another HD-DVD (Black Christmas) where i just removed the Pulldown and set FPS to 23,976 that worked like a charm but on this one not -
Niether HD-DVD nor BluRay supports 1080p 29.97 fps. I suspect your source is actually interlaced.
I haven't seen this before but the video appears to be stored as 23.976 fps progressive with flags telling the player to play it at 29.97 fps. TsMuxer with the frame rate changed to 23.976 and remove pulldown worked with the sample clip. Maybe it was to short to show the errors you were getting? AviSynth can open it properly with:
Code:DirectShowSource("nocandys.m2ts", convertfps=true, fps=23.976)
^^Do you mean extract the h264 stream from EVO with tsMuxer (with (?) or without (?) Removing Pulldown) and Remux it with mkvmerge writing 23,976 fps to the Video stream?
I tried something similar yesterday: I remuxed the pure .h264 29,970 fps Video stream with eac3to (which removes Pulldown automatically) to mkv but the Result was the same like with tsMuxer > Audio async -
Yes with Windows Media Player
But all I want is to get it to 23,976 fps for my TV with Audio sync like Normal BluRay's they are in 23,976 fps too
I've that removing Pulldown with h264info should solve the Problems better than tsMuxer but it's very strange Version 24 to the latest v26 crashes immediatelyVersions 20 to 23 are working and from that what i see after removing Pulldown with h264info Video Plays very smooth and it Shows up no Errors but the Picture i get is very very Faulty this is how it Looks like:
Maybe someone could try h264info with the sample and tell if it Looks the same way or different > would be very Grateful -
^^I Tried that demux with eac3to doesn't workgetting an Error:
eac3to v3.24
command line: "D:\eac3to\eac3to.exe" "E:\HVDVD_TS\FEATURE_1.evo" "D:\HDDVD\movie.h264" -demux -keepPulldown
EVO, 1 video track, 4 audio tracks, 7 subtitle tracks, 0:43:05
1: h264/AVC, 1080p24 /1.001 (16:9) with pulldown flags
2: E-AC3, English, 5.1 channels, 1536kbps, 48kHz, dialnorm: -27dB, -84ms
3: E-AC3, French, 5.1 channels, 768kbps, 48kHz, dialnorm: -27dB, -84ms
4: E-AC3, Spanish, 5.1 channels, 768kbps, 48kHz, dialnorm: -27dB, -84ms
5: E-AC3 Surround, English, 2.0 channels, 192kbps, 48kHz, dialnorm: -27dB, -84ms
"Commentary"
6: Subtitle (DVD), English
7: Subtitle (DVD), English, "SDH"
8: Subtitle (DVD), French
9: Subtitle (DVD), Spanish
10: Subtitle (DVD), Portuguese
11: Subtitle (DVD), French, "Forced Frecnh"
12: Subtitle (DVD), Spanish, "Forced"
[v01] Extracting video track number 1...
[a02] Extracting audio track number 2...
[a03] Extracting audio track number 3...
[a04] Extracting audio track number 4...
[a05] Extracting audio track number 5...
[a02] Removing E-AC3 dialog normalization...
[a03] Removing E-AC3 dialog normalization...
[a03] Applying (E-)AC3 delay...
[a05] Removing E-AC3 dialog normalization...
[a02] Applying (E-)AC3 delay...
[a04] Removing E-AC3 dialog normalization...
[a03] A remaining delay of -4ms could not be fixed.
[a05] Applying (E-)AC3 delay...
[a02] A remaining delay of +1ms could not be fixed.
[a04] Applying (E-)AC3 delay...
[a05] A remaining delay of +12ms could not be fixed.
[a04] A remaining delay of -4ms could not be fixed.
[v01] Creating file "FEATURE_1 - 1 - h264, 1080p24.h264"...
[v01] Creating file "D:\HDDVD\movie.h264"...
[a02] Creating file "FEATURE_1 - 2 - E-AC3, English, 5.1 channels, 1536kbps, 48kHz.eac3"...
[a03] Creating file "FEATURE_1 - 3 - E-AC3, French, 5.1 channels, 768kbps, 48kHz.eac3"...
[a04] Creating file "FEATURE_1 - 4 - E-AC3, Spanish, 5.1 channels, 768kbps, 48kHz.eac3"...
[a05] Creating file "FEATURE_1 - 5 - E-AC3 Surround, English, 2.0 channels, 192kbps, 48kHz, 'Commentary'.eac3"...
[s09] Extracting subtitle track number 9...
[s10] Extracting subtitle track number 10...
[s06] Extracting subtitle track number 6...
[s07] Extracting subtitle track number 7...
[s08] Extracting subtitle track number 8...
[s11] Extracting subtitle track number 11...
[s12] Extracting subtitle track number 12...
[v01] Writing the destination file failed. <ERROR>
Aborted at file position 921698304. <ERROR> -
also checked the EVO-File with eac3to Command -check
Here is what i get:
http://www.sendspace.com/file/27vld9 -
Hi Guys! Good News
I Downloaded eac3to 3.27 and tried demuxing again but it was resulting in the Same Error (dont't know why got Plenty of Space Free on D:\ (about 20 gb) but figured that out: I Forced eac3to to demux the EVO-File and Output on D:\ , eac3to did that but its only a copy of demuxed h264 Fileeac3to seems to demux the Files First to C:\My Documents\ anyway > where wasn't enough Space for demuxing (2 gb) and on my First try i didn't noticed that the Files are going on C:\First..my Fault
After demuxing with -keepPulldown i get an h264 File with 23,976 FPS from eac3to which Plays smooth on PC and TV with especially Sync Audio now> Great !!!!
Now i just have do to the same with the second EVO-File (movie is Splitted is 2 Parts on the Disc)
Thank You very much to all of You Guys for Helping me to get this Fixedvery Happy and satisfied now
No idea, but that looks okay to me. It sounded like you were going to demux to two separate .h264 files and try to combine them with something else.
Anyway, you'd better edit the title of this topic...
Replacing the expression "> PLZ Help :–(" with the tag [SOLVED]would be nice
Sword is no substitute for kitchen-knife.
Handbrake Lowering FPS issue (29.970 to 23.976) - Should I be concerned?
By kingaddi in forum DVD RippingReplies: 20Last Post: 3rd Sep 2012, 00:16 -
Honoring Pulldown Flags
By unclescoob in forum DVD RippingReplies: 10Last Post: 26th Jul 2012, 09:14 -
Remove pulldown? (29.97 -> 23.976)
By Asterra in forum Newbie / General discussionsReplies: 2Last Post: 5th May 2010, 19:12 -
To synchronize 29,970 audio fps for 23.976 fps
By DruidCtba in forum Newbie / General discussionsReplies: 1Last Post: 27th Sep 2009, 12:01 -
Sync 29.970 FPS audio to 23.976 FPS video?
By LCO1971 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 15:23
