hello.. i want rip from Bluray 3d.. to 3d half-sbs using ripbot... anyone know how to do it?
Can Ripbot do that? I confess I'm not using the latest version, but I'm not seeing it in the changelogs.
OTOH, DVDFab *can* do SBS from 3D Blu-ray. I tested it a couple of times, and it was simple enough. You shouldn't need step-by-step instructions.
BDRB can also do it, although I haven't tested it. Note that if you're not doing the re-encode direct from disc (i.e. running a driver-level decrypter in the background), you should rip full disc to hard drive as an ISO image. Then mount the image with Virtual Clone Drive or whatever and point BDRB at that.
Good luck.Pull! Bang! Darn! -
Checkout this guide:
https://github.com/rodrigopolo/brripguide/blob/master/guide_en.md
And in spanish
https://github.com/rodrigopolo/brripguide/blob/master/guide_es.md
Full SBS to Half SBS
By sjb8622 in forum Newbie / General discussionsReplies: 0Last Post: 9th Jan 2013, 00:38 -
How to convert Half SBS to Anaglyph 3D
By VHser in forum Video ConversionReplies: 4Last Post: 9th Sep 2012, 16:42 -
Half SBS Video with FFmpeg
By PsyDonias in forum Video ConversionReplies: 4Last Post: 8th Jul 2012, 22:35 -
hsbs to half sbs
By Pabbi in forum Video ConversionReplies: 1Last Post: 13th Jun 2012, 14:14 -
remove subtitles from half SBS movie
By sportflyer in forum SubtitleReplies: 2Last Post: 1st Jan 2012, 23:27
