Hello!
The PAL or the NTSC AVCHD camcorders record cleaner video picture at the same bitrate?
Forexample: PAL Canon LEGRIA HF G30 or NTSC Canon LEGRIA HF G30 ?
Because I like to capture video frames as pictures....
My concept:
Pal record 25p/50i 50p, the NTSC record 30p/60i/60p pictures/sec, therefore I think the compression ratio/frame of the NTSC camcorders are worse. Do you know such comparisons?
But: Is this true in practical life?
Thank you fro your reply!
You would never choose a camcorder based on this.
While it's true that "PAL" framerates give you a theoretical 20% quality boost (good luck noticing it though), using a 50Hz camera under certain 60Hz lighting can give flickering - which is going to kill the compression algorithm and more than outweigh any quality gain.
Some "NTSC" camcorders have a 24p option.
People choose between the two based on price, local availability, compatibility with local video standards and equipment, and the flicker problem under certain lighting. If a theoretical 20% quality boost (invisible unless there's fast motion; maybe invisible even then) is more important than all these things, then maybe a still camera which can shoot 6-10 full resolution (10MP+) frames per second would be more appropriate?
Cheers,
David.
60fps versus 50fps? PAL or NTSC in AVCHD?? need advice!
By ftitus in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 15th Nov 2010, 06:11 -
PAL to NTSC Picture Quality?
By Mike99 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 13th Aug 2010, 04:28 -
Switched from ntsc to pal not no picture! Help
By sungate in forum Newbie / General discussionsReplies: 9Last Post: 24th Jun 2010, 07:02 -
(pal) LG RHT497H - Can it record NTSC?
By dave_van_damme in forum DVD & Blu-ray RecordersReplies: 2Last Post: 18th Nov 2009, 11:59 -
How to record NTSC on a PAL dvd recorder?!
By Dekaspace in forum Newbie / General discussionsReplies: 8Last Post: 3rd Jul 2008, 23:21
