hi
how to set the folder i want when capturing images while watching videos?
all the pics goes to My Pictures but i don't see how i can change that
greetings
When you click 'Save Image' it first prompts for a location to save to. It should remember this location after a restart.
No need to delete previous (old folder) locations where images were previously saved. Simply open the video, and while playing click File>Save Image As (Alt-I) and browse to any folder (newly created or existing) and save that image there. From that moment on, you can press F5 to keep snapshots saved to that folder of any video you play. MPC will remember the last 'save image as' folder until you repeat this process to change the save location. I repeat: Do not delete any folders. That is not needed. Hope this clears up this older topic. Having gone through a frustrating evening of covering a work requirement, I figured this out. I had to save ten random images from ten specific videos in ten different folders. This worked.
Think: You do not want to save some images to the wrong folder, oops.Last edited by milo77; 19th Aug 2017 at 05:14.
Always +125% video/Frame/Zoom size MPC-HC/MPC-BE?
By tigerb in forum Newbie / General discussionsReplies: 6Last Post: 8th Mar 2013, 16:57 -
how to use two MPC with different settings?
By SignedupGuest in forum Newbie / General discussionsReplies: 5Last Post: 22nd Feb 2013, 18:50 -
MPC-HC settings?
By Hoser Rob in forum Software PlayingReplies: 4Last Post: 22nd Jan 2012, 10:51 -
Changing VLC or MPC settings to maximize quality?
By awaisuk in forum Newbie / General discussionsReplies: 1Last Post: 15th Aug 2011, 07:51 -
some general MPC settings questions
By THX-UltraII in forum Newbie / General discussionsReplies: 1Last Post: 25th Nov 2008, 08:28
