I have an old (very old) SONY TV - 1969. It only has an RF ie co-axial aerial socket on the back. No SCART, No composite - absolutely nothing other than the RF input. This set was bought in the UK, which I understand is PAL Type I. I now live in Australia and I'd like to get this TV running. The analogue signal is being turned off in two weeks and I'm aware of this and have bought a digital set top box. This STB only has composite and HDMI outputs. Again, I'm aware of this and I have a composite to RF converter but I'm told that there will still need to be a frequency converter, so that the STB output will be compatible with this UK TV.
Any suggestions or assistance would be greatly appreciated.
Any reason you are using such an old tv?You can get a fairly new tube tv for close to free in most areas with the connections you need.
Try looking for a rf to composite adapter that will work with your setup.Last edited by johns0; 15th May 2013 at 02:14.
Have to echo what johns0 is saying. You are using a proverbial sledge-hammer to crack a nut.
That vintage 1969 tv could peg it anyday. In fact it could even peg it the moment you plug in these adapters.
More than that even if you get it to work you lose all the benefits of the digital signal. Better now to hedge your bets and invest in a compatable tv.
In fact, you might even have been able to save on the stb as many tv's have the receiver built-in. -
My parents bought me this TV when I was kid in England. It's always been around. I just can't imagine it not being there. I've got it on a wall stand, like an ornament - seems such a waste not to use the TV that I saw the first transmitted episode of Columbo on. It would be so nice if I could get it up and running.
I don't want it just as a TV. $250 buys a digital TV nowadays - I've had this SONY since new. I saw some of the most iconic TV programs on this set. Ironside, Columbo, 6 Million Dollar Man, Mary Tyler Moore Show etc etc etc. This TV has been with me through thick and thin.
I owe it big time... -
It looks to me like the difference between is PAL B and PAL I is the audio carrier frequency. That's only a matter of the RF modulated signal. I think all you need is an Australian RF modulator. Run composite and left/right audio to the modulator, output of the modulator to the TV. Something like this:
http://www.247deals.com.au/product/1510
LaCie PlayHD 2TB - how to change to PAL - no video signal
By b3rnz1 in forum Newbie / General discussionsReplies: 1Last Post: 18th Nov 2012, 04:32 -
SDI, Component(Y), Composite in PAL signal
By luckyo in forum Capturing and VCRReplies: 0Last Post: 18th Jun 2012, 07:22 -
capturing PAL signal as 1080i, 720p or just PAL ?
By adom in forum Capturing and VCRReplies: 3Last Post: 30th Aug 2011, 05:10 -
Convert PAL Signal to NTSC for USA HD Plasma
By hilite in forum DVB / IPTVReplies: 5Last Post: 25th Aug 2011, 06:11 -
PAL Video Cassette Recorder or [Multisystem VCR] for PAL->NTSC playback
By quantass in forum Newbie / General discussionsReplies: 10Last Post: 12th Dec 2008, 13:47
