Is there a Sachtler fluid head + tripod below $1800? Is it realistic?
I would like to use it for wedding cinematography. The weight load would not exceed 10LB.
Thanks so much!
I wanted to stay away from the ACE system. People say that the legs are not really sachtler quality.
Can you recommend the FSB6 with Carbon legs? http://www.bhphotovideo.com/c/product/498220-REG/Sachtler_0450_0450_FSB_6T_with_75CF.html
I would like to use it for wedding videography where the weight load would not exceed 10LB. -
The FSB6 is good, but I have to ask: what is the cam that is going on there? And what OTHER accessories/peripherals will be attached to it (monitor, batteries, rails, lens hood, etc)? Because that all adds to the weight equation.
Scott -
Nikon D4 + 70-200mm 2.8 VR + Rode mic on the hot shue.
Ok, so you're looking at ~8 1/2 pounds (~3 + ~5 + ~ 1/2) just with those alone. Since the above linked sticks is rated to 13.2 lbs., that's still within the comfort zone. If you actually went up to 10-11 lbs, you'd be pushing it, because even if it says it's rated to 13.2, that just means it can safely HOLD/SUPPORT that much weight. It doesn't mean it will be STEADY. You need a much sturdier rating to maintain steadiness than just to maintain support.
Scott -
Yes, that's correct! I want to be below the weight limit for sure.
Realistic lipsync animation
By jimmyy in forum EditingReplies: 17Last Post: 13th Jan 2013, 17:06 -
Realistic video resolutions and DSLR's.....
By nateo200 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 15th Sep 2011, 14:15 -
Fine tuning for tripod ball-head?
By acusman in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 10th Apr 2011, 20:28 -
Bogen Manfrotto 3063 Fluid Head Wobble
By birdbrainz in forum Newbie / General discussionsReplies: 4Last Post: 29th May 2010, 15:43 -
ORBYX: Fluid DVD boombox 1607001?
By snako in forum DVD & Blu-ray PlayersReplies: 0Last Post: 2nd Jan 2010, 22:29
