Hi,
My brain has just gone to overload on trying - really trying to get it to work.
I am on a linux os porting through wine v1.3.
It was workiing great until recently and now i just can`t figure what goes where.
Yes, i have read through some posts here, including my own but nothing works. This is weird .
I will detail what my method is , see if someone can pinpoint .
- Download from source the .zip , stable version and unzip to C/programfiles/VirtualDub
- Download the 200 plus plugins .zip pack , unzip and place into plugins folder
- Download FFdshow and place in Virtualdub.folder
- Download FFmpeg and place in Virtualdub folder
- Download Xvid and place in Virtualdub folder
When the program crashes i unpack FFdshow and place in plugins . I also do the same with FFmpeg and crashes.
Along the way a folder called plugins32 gets created into which i place .........well, my user name say`s it all.
Please can someone help meeeeeeeeeee.....show me the way .
Thanks to anyone who can !
	I tried just the simple install ( as is ) , with a normal .avi and the program sits there for a few seconds and then it`s gone !
 What`s happening here, surely i`m not the only one.
 I could use some help, Thanks.
  Audio preview does not work in VirtualDub. Suggestions?By Spektre in forum Capturing and VCRReplies: 5Last Post: 13th Jan 2013, 10:07
  VirtualDub 64bit doesn't work with ffdshow?By shun in forum AudioReplies: 2Last Post: 21st Dec 2012, 21:40
  Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SVBy CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 12:26
  Virtualdub Deshaker filter has ceased to workBy MrPerson in forum EditingReplies: 0Last Post: 29th Apr 2009, 01:04
  confused with divx files that workBy ceve4life in forum Authoring (DVD)Replies: 3Last Post: 30th Jul 2008, 17:42
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
