Been a while since I've messed around with capture software. Figure there is a better program out there now then there was 10 years ago.
I'm looking for the best way to capture video in an already compressed format (xvid). Is there any kind of freeware out there that will allow me to? Virtual Dub able to do that now? Or am I doomed to record into default mp4 format in windows and then convert after the fact.
Hard for me to search internet properly to do research, currently deployed with army and on terrible connection. I'd like to make some short videos for family back in States as easily as possible. Want to avoid converting to Xvid if I can capture it in a native xvid format.
Any advice on software to use? Also, I'm on windows 8 right now if that matters.
VirtualDub + Xvid is ok. Just be sure to use settings fast enough for realtime compression.
Thanks, I figured it would be good enough. Always loved virtual dub, it can do a lot and doesn't take up much space. Now, have to wait 20 mins for it to DL on my shitty satellite connection haha. Thank you for confirmation of my current idea.
If you're not looking for max compression, Divx is twice as fast as Xvid when both are at their fastest settings.
A good software to capture and record video from webcam.
By prankstare in forum Video Streaming DownloadingReplies: 10Last Post: 12th Dec 2018, 22:40 -
Open-source software to record video from webcam?
By kg123 in forum ComputerReplies: 30Last Post: 22nd Nov 2016, 21:15 -
Using a USB webcam to record..
By SE14man in forum Newbie / General discussionsReplies: 5Last Post: 11th Oct 2012, 12:16 -
Simple Software to record video from my webcam
By herscht in forum Capturing and VCRReplies: 5Last Post: 29th Aug 2012, 12:29 -
Webcam record and upload like Youtube's?
By sdsumike619 in forum Video Streaming DownloadingReplies: 0Last Post: 31st Jul 2009, 12:33
