hey everyone c:
i'm currently using freemake video converter ver 4.0.1 and haven't had any noticeable issues with it.. until now
my TV is very picky with what type of file it will play via USB. so far, i've found that AVI is the best bet, but, after converting season 1 of "the secret circle" i noticed that some of the video itself had either disappeared or frozen on a frame, until the video had caught up to where it would start playing again. i've never had issues like this before (although i've only just recently started using freemake) so i'm really confused and have no idea how i could fix or prevent this from happening. the original MP4 files work fine, from start to finish, they just don't play on my TV.
the output i'm choosing for these files is preset to; TV Quality, XViD, MP3 then it says "size up to 640x480"
i really hope someone can help out! thanks for your time c:
	i tried using WinFF but it ended up taking so long to convert just one file that i gave up haha. any other freeware you can recommend that converts to AVI? (keep in mind it's to play on my TV and it doesn't support HD or majority of the formats out there)
 would the frame height and width be contributing to the problem do you think? it get's changed when i convert (it's a preset)
  Cut A Video without losing quality in x264By kaaviyan in forum EditingReplies: 5Last Post: 27th Jan 2013, 13:06
  Best video converter for converting .mov without losing quality?By sk8erboi in forum Video ConversionReplies: 1Last Post: 6th Nov 2012, 05:12
  Video and Audio different lengthBy pchan in forum AudioReplies: 3Last Post: 15th Aug 2012, 04:46
  Change length of an AVI. Reduce/Increase Frame LengthBy Buzwinkle in forum Authoring (DVD)Replies: 4Last Post: 10th Aug 2011, 09:08
  How to email video without losing clarityBy Tiger2 in forum Video ConversionReplies: 9Last Post: 28th Feb 2010, 08:01
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
