here is my prob i have just encoded a movie (pearl harbor) and the file size is currently 2.8gb i want to cut this down to 4 differnt files obviously because i want to fit the four files on cds. so does anyone know of any good software which i could use to cut this file up?
Mikey :lol:
Depends on the format. I recommend VirtualDub if it is an AVI. If you are talking about a MPEG I do not recommend anything, but if you want to edit a MPEG by all means, use M2Edit Pro.
or bbMPEG or just have a look at our famous "how to edit" section. -
its a mpeg 2 svcd file i am using what makes it more diffcult to edit the mpeg rather than the avi? or is it you dont know any software to edit the mpeg? and is there anything wrong with m2edit pro?
Mikey :lol: -
http://www.vcdhelp.com/editmpg.htm
Editing a MPEG might be more difficult. Make sure, the editor cuts before an I-frame otherwise you may end with sync problems.
Resizing and joining two avi files and keeping file size down
By wayc00lio in forum Newbie / General discussionsReplies: 5Last Post: 16th Feb 2011, 10:18 -
Compressing/resizing a MKV video file
By [ss]vegeta in forum Newbie / General discussionsReplies: 13Last Post: 9th Oct 2009, 16:01 -
Resizing video file size using handbreak question.
By demonhunter in forum Video ConversionReplies: 2Last Post: 19th May 2009, 06:23 -
resizing help
By shaktiIIIgta in forum Newbie / General discussionsReplies: 14Last Post: 15th Nov 2008, 21:52 -
Help resizing media file(s)
By AORMan in forum Video ConversionReplies: 4Last Post: 6th Oct 2007, 02:52
