Hi all,
First post so hopefully in the right section. I am an avid Australian based movie buff and purchase many dvd and blu-rays. Up till now I have used a region-free DVD player to play US DVDs however I am wanting to play US Blu-rays as often they are cheaper than the UK Blu-rays or sometimes the movie may only be available on US blu-ray. I am aware that the Blu-ray region coding is different to that of DVD however the cost of getting modified blu-ray players in Australia is on the expensive side so have been looking for other options. I thought of buying a cheap US blu-ray player but then would have to fiddle with the power. I do however own a western digital mini media player that has a USB input for external drives. Sooo... would this accept a USB powered portable Blu-Ray player? If so, I assume a US one would be able to play US blu-rays. Your advice would be appreciated.
Thanx
David
the usb port on your western digital mini media player may not provide enough power for your portable bluray player so
it might be a good idea to find one with it's own power supply -
Just get a zone-free blu-ray player (for BD as well as DVD). Contrary to what you believe, there are players that do this woithout needing hardware modification. They can be found and aren't expensive. I have two a Toshiba that cost me $NZ 129 (circa $A 100) and a Veon which cost me $NZ 50.
The Toshiba 1200ky and Toshiba 3200ky should both be readily and cheaply available in Australia, and the Australia firmware that de-zones them is readily. Then you just press "Setup" on the remote and enter "8520". A new menu will appear that lets you change the DVD and Blu Ray regions. I have the 1200 model, and can confirm it works. Interestingly, the remote control codes for the Veon are identical. I also understand that the Soniq B100, which JB HiFi were selling, works the same as well (I haven't verified this). -
Do what Chopmeister suggested.
I want to be absolutely clear about this - if you want region free anything, DO NOT buy Sony or Samsung or you will very likely regret it. That's what makes his suggestion great - he doesn't suggest using anything by Sony or Samsung. -
I have only seen USB-powered external Blu-ray drives, not actual USB-powered portable Blu-Ray players. If this item really is a player, not just a drive, I'd be interested to know more about it.
If it is only a USB-powered external Blu-ray drive, it would never work for what you want to do. Most Blu-Ray discs made for the US have AACS copy protection, which means the playback device has to be able to decrypt the disc's contents in order to play it. So, even if the WD player could power the drive and access it, that combination of equipment would not allow you to watch the movie because your WD player doesn't have the ability to decrypt AACS-protected material.
Western Digital Media Player Thumbnail help
By DebCoom in forum Media Center PC / MediaCentersReplies: 3Last Post: 19th Feb 2011, 08:06 -
Western Digital HDMI USB Media Player?? (WDAVN00BN)
By Inspex in forum Media Center PC / MediaCentersReplies: 552Last Post: 7th May 2010, 12:33 -
Western Digital TV Live HD Media Player
By dvdsham in forum Newbie / General discussionsReplies: 4Last Post: 1st May 2010, 23:32 -
Western Digital HD MEdia Player alternatives?
By peggypwr1 in forum Newbie / General discussionsReplies: 13Last Post: 28th Feb 2009, 16:15 -
Universal remote-Western Digital WD TV HD Media Player
By interpidp in forum DVB / IPTVReplies: 4Last Post: 8th Jan 2009, 02:57
