Im capturing long videos and from time to time, when i hit the stop button for end the capture proccess, i dont get the window asking for the final filename. The main capture window stays still some time and then it shows itself as ready to capture again as if i putted the filename. The thing is the file is created, but when i try to import it it says damaged or unsupported format. Some other times (the most) this filename window does apperar and when i define the name and hit ok, i can see in Finder that the file that was beeing created generates a thumb, that de "corrupt" file doesnt ever get to generate because i think its not "closed", but i dont understand the inner proccess so its just a guess.
So the thing is, is there a way to fix this file? its 2hr capturing and its not the first time it happens, so id be very grateful if you can help me.
Thanks in advance
System: Macbook Pro i7 2.6ghz 16gb ram 512gb ssd OSX 10.8.3 w/updates
Capture: Sharp HI8 camera > AVT-8710 > Blackmagic Intensity Shuttle Thunderbolt > Premiere CS6 > JPEG Compression
What container? Mp4/m4a, mov?
Try open with mpeg streamclip and avidemux. -
Hi Baldrick! thanks for your answer. Im recording in QuickTime JPEG, its not uncompressed but its still QuickTime.
MPEG Streamclip says first "unrecognized filetype", and 2 options, Close and Open Anyway, i hit Open Anyway and after the analysis, it says "Cant find video or audio tracks"
Avidemux says "Cannot find a demuxer for Untitled Clip 05.mov" -
Quicktime=mov. Maybe try video repair tool or mp4repair.org but they aren't free...I don't know any other free methods.
Looking for a Damaged AVI File
By Ancalagon in forum Newbie / General discussionsReplies: 0Last Post: 23rd Apr 2013, 06:05 -
tsmuxer unsupported format?
By benson733 in forum Authoring (Blu-ray)Replies: 1Last Post: 19th Sep 2012, 23:48 -
Unsupported audio format in MKV file on LG 47LW5600 TV.
By kmplsv in forum Video ConversionReplies: 5Last Post: 23rd Feb 2012, 09:03 -
Unsupported format or damaged file -> ?
By ermetekos in forum EditingReplies: 1Last Post: 31st Mar 2010, 11:56 -
Unsupported FLV codec or format
By lovyagin in forum EditingReplies: 25Last Post: 11th Dec 2008, 23:13
