I've got a Divx Mpeg4 file-25fps(according to VDub), and the .sub subtitle files that I want to add while frameserving with AVIsynth when I encode with either TMPG or CCE.
I'm new to using AVIsynth, so I've been writing my script one line at a time, making sure the media player will still read the file after each addition. I'm getting stuck when I get to the Vobsub.dll line.
I get the following error:
the script's return value was not a video clip.![]()
here is my script:
directshowsource("G:\temporary movie files\wolf1.avi")
bicubicresize(576,480)
loadplugin("c:\winnt\system32\vobsub.dll")
any help would be greatly appreciated
I think you have to change the order.
avisource("G:\temporary movie files\wolf1.avi")
bicubicresize(480,576)
vobsub("G:\temporary movie files\wolf1") -
Thanks for the quick reply
the video is now playing, however the subs are not there.
also, do I need to run VobSubconfigure first? when I do that, I can open the subtitle file, but the "ok" button remains greyed out.
thanks again for the help -
hmm, how did you create the subtitles? It sounds to me, that you have downloaded subtitle files and you are not sure which format it is.
If the .sub file is created by vobsub, just open the .sub in vobsub config, write a new index and write an Avisynth script as shown above.
If you have the subs in MicroDVD(.sub) format,
http://www.vcdhelp.com/srtsubsvirtual.htm
convert it to .ssa and load the subtitler filter for VirtualDub into your Avisynth script.
AVIsource("D:\test\testtesttest.avi")
ConvertToRGB
function VD_Subtitler(clip clip, string filename)
LoadVirtualdubPlugin("C:\Program Files\VirtualDub-1_4_9\plugins"+"\subtitler.vdf", "_VD_Subtitler")
return clip._VD_Subtitler(1, filename)
VD_Subtitler("D:\test\test.ssa") -
I believe the subs are in MicroDVD format(the are .sub files), so I'll give that a try when I get home tonight.
I have a few questions, though, about the script...
1) is that the exact format I need, including the ended quotes and the (plus) like you have written?
--thanks again for your all of your help--I'm still new at AVIsynth scripts
ConvertToRGB
I do not use VirtualDub filters with Avisynth. I just copied it from the vdfilters.avs, that you can download here, the vdfilters.avs is part of the Avisynth 1.0b3 package.
I only change the bold text, i.e. the pathes to the avi, ssa and .vdf. The rest I left untouched and it worked. I added the ConvertToRGB line, because my source was YUY2 and VDfilters work in RGB colorspace only.
Now it's your turn to figure out, what the rest of the script means. -
truman...
thanks for all your help--I got it to work!
...at least with TMPG--CCE is being really fussy. although...I did forget to try the resampleaudio(44100) line in the script...
thanks again!
Problem hardsubbing Vobsub with Avisynth/VSFilter
By gklitt in forum Video ConversionReplies: 0Last Post: 1st Jul 2011, 16:43 -
problem with VobSub
By nazim in forum SubtitleReplies: 4Last Post: 23rd Jun 2011, 15:32 -
Vobsub
By leftspeaker2000 in forum SubtitleReplies: 0Last Post: 31st May 2011, 10:41 -
Vobsub (or just sup??) for HDPlayer
By qknet in forum SubtitleReplies: 5Last Post: 28th Dec 2010, 18:38 -
Vobsub in Avidemux
By Kurgan71 in forum DVD RippingReplies: 5Last Post: 18th Feb 2009, 02:50
