  1. when trying to load a lagarith or ut screen recorded avi in premiere 5.5 it only loads a few seconds or minutes of the video.. not the entire vid.. the vids are 30-50gb... but it doesnt conform just loads as if it is loading a 10 mb video and ye only has a little bit of the vid...
    any assistance appreciated, cheers...
    Oct 2005
    666th portal
    it would help if you filled out the computer specs of the editing machine in your profile. also use mediainfo in text mode and copy/paste the results here of the videos.
  3. is strange , tried encoding lagarith for 57 mins with hypercam and camtasia,
    camtasia:
    General
    Complete name : D:\Camtasia Lagarith Capture.avi
    Format : AVI
    Format profile : OpenDML
    File size : 25.1 GiB
    Duration : 57mn 10s
    Overall bit rate : 62.9 Mbps
    Video
    Format : Lagarith
    Codec ID : LAGS
    Duration : 57mn 10s
    Source duration : 40mn 0s
    Bit rate : 104 Mbps
    Width : 1 600 pixels
    Height : 1 200 pixels
    Display aspect ratio : 4:3
    Frame rate : 30.000 fps
    Color space : RGB
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 1.800
    Stream size : 41.4 GiB
    Audio
    Format : PCM
    Format settings, Endianness : Little
    Format settings, Sign : Signed
    Codec ID : 1
    Duration : 14mn 17s
    Bit rate mode : Constant
    Bit rate : 352.8 Kbps
    Channel(s) : 1 channel
    Sampling rate : 22.05 KHz
    Bit depth : 16 bits
    Stream size : 36.1 MiB (0%)
    Interleave, duration : 2797 ms (83.92 video frames)
    Interleave, preload duration : 1000 ms
    hypercam:
    General
    Complete name : D:\Hypercam Lagarith Capture.avi
    Format : AVI
    File size : 40.6 GiB
    Duration : 57mn 39s
    Overall bit rate : 101 Mbps
    Video
    Format : Lagarith
    Codec ID : LAGS
    Duration : 57mn 39s
    Bit rate : 101 Mbps
    Color space : RGB
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 1.750
    Stream size : 40.6 GiB (100%)
    both arent able to be effectively loaded and edited into premiere 5.5,
    who would have thought recording and editing ur desktop would be so difficult
  4. No idea why , I use large files in premiere frequently, including lagarith sometimes . UT works well, but it seems you have the same problems with it ?
    But look at the discrepancy in the audio time for the 1st file, maybe it's corrupted or causing premiere confusion
    Video
    Duration : 57mn 10s
    Audio
    Duration : 14mn 17s
    Stream size : 36.1 MiB (0%) <= 0%WTF ?
    But that doesn't explain the 2nd file (looks like no audio)
  5. that recording was anomalous , im not recording in audio
    so they are both loading in now.. i create a sequence from the clip, edit up a small section of it
    then when going to export, i set it to match sequence settings, and it tightens up the dimensions so that is not full screen anymore and the speed is out of sync, so its like double or something.
