What tool can I use to make the following conversion? I just want to combine the video file with two audio files of L/R channels.
INPUT:
M2V - video only file
Wave file #1 - mono, PCM, 16-bit
Wave file #2 - mono, PCM, 16-bit
OUTPUT:
single MKV or m2ts file with stereo
MediaInfo on the input video file:
Code:General Complete name : E:\Video\Tape_01.m2v Format : MPEG Video Format version : Version 2 File size : 7.06 GiB Duration : 40mn 25s Overall bit rate : 25.0 Mbps Video Format : MPEG Video Commercial name : HDV 1080i Format version : Version 2 Format profile : Main@High 1440 Format settings, BVOP : Yes Format settings, Matrix : Custom Format settings, GOP : M=3, N=15 Duration : 40mn 25s Bit rate : 25.0 Mbps Width : 1 440 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 29.970 fps Standard : Component Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First Compression mode : Lossy Bits/(Pixel*Frame) : 0.536 Stream size : 7.06 GiB (100%) Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709
I would try Audacity. I believe there's a way to combine two mono streams, but i can't remember how at the moment. IIRC, you open both files at once, right click on them and select "Make Stereo" (or something to that effect), and export as WAV. Then, import the new file into a muxing program (e.g. MKVMerge) just like any other WAV.
Convert/Mux .m2v and .wav into mpeg for DVD??
By Beavis in forum Video ConversionReplies: 2Last Post: 22nd Jul 2011, 14:46 -
Trying to create DVD from m2v and wav files
By JSLayton in forum Authoring (DVD)Replies: 8Last Post: 28th Jun 2011, 17:56 -
How to mux a m2v file with 44.1khz, 16-bit wav?
By seven_deuce offsuit in forum Newbie / General discussionsReplies: 2Last Post: 24th Apr 2011, 22:25 -
Encoding WAV and M2V to AVI [high quality]
By duudo in forum Newbie / General discussionsReplies: 2Last Post: 28th Feb 2009, 05:57 -
have m2v+wav and chapter points, what's next?
By shun in forum Authoring (DVD)Replies: 3Last Post: 15th Aug 2008, 09:21
