Hello
I have been having a play with the Sound Forge Audio Studio software. When i come to play back the recordings i have made there is no sound. I have no problems playing other audio or video files on on my desktop the sound comes through my headphones.
I also noticed this when i tried Total Recorder sound recording program.
Can anyone please advise?
Are you actually saving them? Are they being saved as midi files or something like that?
I`d suggest opening the sound mixer on the bottom right hand corner of screen (obviously openable from Control Panel as well) , it sounds like you have the sound level for Sound Forge either turned off or at zero . Either that , or as transporterfan suggests you have codec problems .
Llamas are for life , not just for christmas -
Thanks for replies.
Yes, to saving files. Sound level is fine. I shall try the codec.
Thanks again -
Wouldn't have expected you to need a codec for an audio file. What format is it saved in?
What does the manual say?
(They are usually very clear about correctly setting up that sort of thing )
Sound Forge puzzler...
By mjl1297 in forum Newbie / General discussionsReplies: 3Last Post: 27th Aug 2011, 09:19 -
Using equalizers in Sound Forge 10
By Xdecade in forum AudioReplies: 0Last Post: 6th Jun 2010, 14:12 -
Sound Forge Help
By ZOMBE in forum AudioReplies: 2Last Post: 28th Jun 2009, 08:46 -
Sound Forge --> Speech Over Background Music
By Omnipulator in forum AudioReplies: 0Last Post: 21st May 2009, 00:00 -
Removing Scratchiness with Sound Forge 8?
By solarblast in forum AudioReplies: 12Last Post: 17th Nov 2008, 11:30
