I notice in the latest build of x264vfw that when I try to enable interlaced encoding, I get a pop-up that it is not supported. I wanted to see if this is something others have run into as well.
I'm trying to convert huffyuv captures (interlaced) down to something more manageable in size. I don't mind a slight hit from lossy compression (if it's a good codec) since this is mostly SVHS, but would prefer to keep the material in its original interlaced form.
You mean the problem happens in the r2273 build by komisar?
You can try an older revision (r2245, for example), OR the revision 2274 by MasterNobody:
http://sourceforge.net/projects/x264vfw/
OPENCL supported x264 encoding
By Stears555 in forum Video ConversionReplies: 3Last Post: 22nd Mar 2013, 04:48 -
Progressive AVI encoding to DVD in TMPEnc - interlaced?
By Xoanon in forum Authoring (DVD)Replies: 16Last Post: 9th Jan 2009, 11:01 -
Re-encoding interlaced order?
By drewzor in forum Newbie / General discussionsReplies: 8Last Post: 27th Sep 2008, 07:06 -
DVD encoding issuses w/ progressive fames plays back as interlaced. SOLVED!
By ty1er in forum DVD RippingReplies: 1Last Post: 19th Aug 2008, 08:34 -
Help with x264vfw
By ingeralhaosului in forum Video ConversionReplies: 1Last Post: 14th Jun 2008, 15:00
