It happens occasionally that I have videos with a small resolution (e.g. 352x264 pixel).
I can run them with a videoplayer like VLC.
But in order to view them in a comfortable way I have always to manually resize the VLC window.
Isn't it possible to change somewhere in the video container header the initial display resolution?
That should be done WITHOUT completely re-encode the video.
Just an embedded simulation of the manual window resize.
How can I do this for *.avi and for *.MP4 containers?
Or is it codec dependent?
Some players have a setting where small videos are automatically rendered at 2x, 3x, whatever. Some players also have the ability to open all videos at some percentage of the Desktop size. VLC has a size multiplier but it's not sensitive to the source frame size. You can set it to 2x but then it will render all videos at 2x, even HD videos.
The MKV container appears to have a "suggested output frame size" option -- at least MMG lets you specify a frame size. I haven't seen a player that supports it though.Last edited by jagabo; 11th May 2013 at 09:42.
Stored Resolution VS Display resolution
By pewe in forum Video ConversionReplies: 6Last Post: 28th Jan 2013, 18:55 -
megui display resolution
By xxxThiefxxx in forum Video ConversionReplies: 2Last Post: 30th Apr 2012, 16:52 -
How can I change (patch) the initial resolution of *.swf/*.flv videos?
By pxstein in forum Video ConversionReplies: 1Last Post: 24th Jan 2011, 16:47 -
same resolution but difference in display w.r.t. height and width
By Pravz in forum Video ConversionReplies: 8Last Post: 2nd Sep 2010, 01:03 -
AVI Video Resolution and TV Display
By sambat in forum Video ConversionReplies: 3Last Post: 23rd Aug 2009, 20:20
