Hello,is there any way to archive a folder (it contains only video files .mkv or .avi) and the archive's size be reduce? For exemple: I'll archive folder "Test" (7GB) and I want that the archive to have 1-2GB, whatever, but it's size to be reduced, I want to backup my anime folders and store them on HDD. Thank you
*sorry for my english*
Results 1 to 15 of 15
Lossless archive compression (.zip, .rar, etc) sees video as nearly random data. More than 2% compression seems unlikely.
The Guide scores in two important respects. Firstly it is slightly cheaper, and secondly it has the words DON'T PANIC inscribed in large friendly letters on its cover. -
1 year ago, I've downloaded an archive (4MB) whitch contains a .avi video file (~900mb). I've searched everywhere for a method to do that. But do you have any suggestion of softwears that can help me?
Using lossless compression ON TOP of something already lossy-compressed (such as your usual video files), can even result in a GROWTH in the filesize, much less the 2% shrinkage max that Case was mentioning.
You've got to remember: 99.99% of video files out there are already VERY, VERY compressed. And most forms of lossy compression ALREADY have an element of lossless compression built-in. The only way to provide more than minimal percentages of further compression is to (decompress &) re-compress via a lossy codec, and incurring much further quality losses in the process. No way around that! And the BEST, MOST EFFICIENT codecs in current use (such as x.264) usually only provide ~100:1 at low bitrates (and therefore LOW quality), compared to uncompressed video. Going from 900MiB -> 4MiB is ~250:1, and would only be remotely feasable if the original was an uncompressed file (and then the video would still look like SHIT). Anything else, as hech54 has already mentioned, is just lies.
Scott -
That's what I said:
...would only be remotely feasable if the original was an uncompressed file (and then the video would still look like SHIT).
BTW, using what basically amounts to a still image as video could be considered "cheating" as that would certainly not be the case with most videos. B&T, or Black, or even credits, are special cases.Last edited by Cornucopia; 10th May 2013 at 15:39.
You MAY get some significant size reduction, IF there is sufficient "common redundancy" in the set of files to be archived. ZIP always compresses files individually, so it's not an option in this case. TAR.GZ, RAR, 7Z and CAB support the "solid archive" mode, and you will have to find out which one "works best" for you. BTW, tar.gz is the worst choice, regarding compression efficiency.
And no, miracles do not happen so easily. -
I wouldn't give such false hope, El Heggunte. Chances are slim to nil. Better to have the OP's eyes opened - then real decisions can be made and real work done.
Scott -
Hopefully the OP has figured out by now that:
- it is not possible to shrink video that's already compressed from 7Gb to 1-2 Gb without taking a lot of time and totally ruining the quality,
- if it were everyone here, especially many of the above who know much more than I, would already be using it,
and start saving for some more computer storage space. -
Thank you for help. xD I hope in the near future will be developed a method.
I would actually & truly bet lots of money that that could/would not happen.
Scott -
The last compression step of all high compression codecs (like MPEG 2, Divx, Xvid, h.264, WMV9, etc.) is entropy encoding -- similar to that used in archive programs like ZIP, RAR, 7z, etc. So the only savings you get by archiving those video files is a little compression of the container overhead and maybe the audio if it's uncompressed PCM. This is not going to change any time soon. Stop wasting your time "hoping".
Best way to archive video files?
By preacher238 in forum Video ConversionReplies: 57Last Post: 31st Dec 2012, 11:17 -
IS ARCHIVE.ORG the best VIDEO Hosting service on Internet?
By Stears555 in forum Video Streaming DownloadingReplies: 5Last Post: 25th May 2012, 00:16 -
MP4 home video metadata - your own video archive/catalog
By maple in forum Video ConversionReplies: 0Last Post: 3rd May 2010, 06:38 -
Best way to archive and view HDV video?
By sgrundy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 8th Dec 2009, 23:21 -
Video workflow and archive advice
By atrick in forum Video ConversionReplies: 4Last Post: 17th Mar 2009, 23:09
