Hello.
I've just registered this forum, as the content has helped me several times before, but now I had a question to which I couldn't find answers, therefore, here I am...
I have recently started using mkv files stored on my external USB hard disk with which I watch the files on my TV through my Sony BD player...
I started using MMG (mkvmergeGUI) to add subtitles...
What I was wondering is:
Is it possible to add 2 subtitles to an MKV file and change between them on a standalone player?
I was aiming to add subtitles of 2 different languages...
I will be trying this soon, but I figured that someone might have already, and wouldn't mind sharing the result/experience...
Thanks in advance.
Regards.
EDIT:
I've just tried adding 2 subs to the mkv and muxing it again, but my Sony BD player just gives the option of turning on and off the subtitles.
What might I have done wrong? Or most likely I missed something, as I'm quite new to MMG...
Hope someone can help, perhaps with some instructions (if it is possible at all to have 2 subs)...
Thanks.
Last edited by maps; 11th May 2013 at 05:28. Reason: added [SOLVED] to thread title, although I'm unsure if I should...
It's just that hardware MKV players, such as Blu-Ray players, usually do not support everything that an MKV can contain - including multiple subtitle streams. I don't think there's a hardware player (other than a computer, that is) that supports more than one subtitle stream in any given video file, but I could be wrong.
If cameras add ten pounds, why would people want to eat them? -
Thanks Ai Haibara.
I was started to get the suspicion that the BD player was the issue.
Can anyone confirm that I will not be able to add 2 subtitles to an mkv and switch between them on a Sony BD player (hardware/standalone)?!
Regards.
EDIT:
I was able to get it to work.
What I had to do was set both subtitle tracks to 'Forced' when muxing, and then I was able to switch between them on my Sony 3D BD player from my USB hard disk.
Perhaps this information might help someone else in the future.Last edited by maps; 11th May 2013 at 05:06. Reason: Solved the issue!
Just wanted to say thanks for this thread! I only wanted to add subs in one language but I wanted optional subs, not hard-coded, and that program worked perfectly. (after hours trying others without success) Thank you!
switchable subtitle in mkv files (Handbrake)
By livevil2702 in forum SubtitleReplies: 0Last Post: 28th Jun 2012, 13:35 -
DVD ripping with switchable subtitles
By jh443 in forum DVD RippingReplies: 3Last Post: 21st May 2012, 14:38 -
iPod touch video with switchable subtitles
By txporter in forum SubtitleReplies: 5Last Post: 13th Jan 2011, 15:35 -
MKV whit switchable subs on PS3 becomes 480p instead of 720p??
By bagmand22 in forum SubtitleReplies: 1Last Post: 13th Sep 2009, 07:17 -
Creating a DVD with Menus and switchable subtitles on Mac OS X
By koke_broke in forum MacReplies: 7Last Post: 27th Mar 2009, 12:43
