    Jul 2001
    knoxville, tn
    Because of the 4G file size limit, I have several 4G files of one show that I have captured. I am wanting to use the Panasonic encoder to encode to MPEG-1 so that I can make a VCD. How do I get it to use all of the AVI files and creat one MPEG-1 file? If I convert each one individually and then join them there is a jerk at the point where they are joined and if I burn them as seperate .mpg files (using Nero) then there is a pause when the DVD player goes from one file to the next. Thanks.
  2. i have done the samething and i get good results.
    First i encode each avi file with panasonic or tmpgenc and after i merge all the mpeg files using tmpgenc.
    Cheers
    Windstar
