Question: For some reason, I just downloaded the new BLADE2 and it's in AVi clip format. It won't play in the DIVX and when i was trying to encode it, it said," file cannot be open, or unsopported!" Any suggestions to fix this idea?? I really want to burn BLADE2.. thanks!!!
1] read the "how to..." section
2]search the forum
3]tell us, which encoder you use
4] higher the priority of the direct show multimedia file reader (if you use TMPG. option > enviromental setting > VFAPI plugin) -
If you can not play the avi with win media player you need the proper codec.
Dazzle dvc100 w studio 12 does it capture AVI 1 or AVI 2 or DV-AVI
By st711 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 17:30 -
avs (avi to avi) ends up out of sync ... winavi output file too big
By mandy in forum Video ConversionReplies: 1Last Post: 21st Aug 2009, 05:56 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 15:38 -
ffmegX v0.09w and converting avi videos into avi.ff.avi videos
By paddymick in forum ffmpegX general discussionReplies: 2Last Post: 2nd Nov 2007, 23:10 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 12:49
