I have been using tsMuxeR and ImgBurn to burn my huge collection of MKV files to Blu-Ray disks. With a few exceptions this has been going well. My problem is that many of my movies are in the 4GB range and I'd like to put them on DVD's instead of BDs. I thought the process would be relatively similar but have been running into issues. Here is what I do.
1.) Use tsMuxeR to convert the MKV to AVCHD output
2.) Use ImgBurn to copy the BDMV and CERTIFICATE folders onto the DVD
I've noticed that when using tsMuxeR, the output for settings using both Blu-Ray Disc or AVCHD are extremely similar, if not the same. In either case, I tried creating both versions and burning them to a DVD.
In the end it says everything is successful, but when I put the DVD into the Blu-Ray player (which IS capable of playing AVCHD content) I just get sound. The Player's menu background stays up while the audio plays in the sound, but no visuals show up. I went back to check that the "level" in tsMuxeR was set to 4.1, and I'm using UDF 2.5 in ImgBurn. Finally, I ensured that the file was in a standard 1280x720 format. I'm a bit lost as to what I'm doing wrong. Do I use a different UDF for DVD's vs. Blu-Ray? Do I not burn the BDMV and CERTIFICATE folders to the disk, and rather something else? I've tried it for several movies but get the same problem every time.
Thanks for the quick reply!
The output for the base MKV is:
General
Unique ID : 198651315478525549997812211672588198927 (0x9572DA08D3E7832D9168BE4EF59FA40F)
Complete name : A:\Movie Downloads\American Pie Presents The Naked Mile-2006-720p.mkv
Format : Matroska
Format version : Version 1
File size : 4.10 GiB
Duration : 1h 37mn
Overall bit rate : 6 021 Kbps
Encoded date : UTC 2008-01-29 17:07:02
Writing application : mkvmerge v2.1.0 ('Another Place To Fall') built on Dec 31 2007 20:13:50
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video
Format : AVC
Format profile : High@L5.1
Format settings, CABAC : Yes
Format settings, ReFrames : 11 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 37mn
Bit rate : 5 635 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.245
Stream size : 3.76 GiB (92%)
Writing library : x264 core 57 svn-709C
Encoding settings : cabac=1 / ref=8 / deblock=1:0:0 / analyse=0x3:0x133 / me=hex / fpel_cmp=sad / subme=6 / me-prepass=0 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=2 / deadzone=21,11 / chroma_qp_offset=0 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=5635 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30
Language : English
Default : Yes
Forced : No
Audio
Format : AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Codec ID : A_AC3
Duration : 1h 37mn
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 268 MiB (6%)
Language : English
Default : Yes
Forced : No
Text
Format : SSA
Codec ID : S_TEXT/SSA
Codec ID/Info : Sub Station Alpha
Compression mode : Lossless
Language : English
Default : Yes
Forced : No
And the output for the muxed AVHCD file is:
General
Complete name : A:\Movie Downloads\Muxed Movies\American Pie Presents the Naked Mile
Format : Blu-ray movie
Duration : 13h 15mn
Overall bit rate : 0 bps
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.1
Codec ID : 27
Duration : 13h 15mn
Bit rate mode : Variable
Maximum bit rate : 40.0 Mbps
Height : 720 pixels
Color space : YUV
Bit depth : 8 bits
Stream size : 31.3 GiB
Language : English
Source : 00000.m2ts
Audio
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Duration : 13h 15mn
Bit rate : 384 Kbps
Bit depth : 16 bits
Stream size : 2.13 GiB
Language : English / English
dialnorm : -27
dialnorm/String : -27 dB
compr : 6.02
compr/String : 6.02 dB
dynrng : 6.02
dynrng/String : 6.02 dB
bsid : 8
dialnorm_Average : -27
dialnorm_Average/String : -27 dB
dialnorm_Minimum : -27
dialnorm_Minimum/String : -27 dB
dialnorm_Maximum : -27
dialnorm_Maximum/String : -27 dB
dialnorm_Count : 2
compr_Average : 6.02
compr_Average/String : 6.02 dB
compr_Minimum : 6.02
compr_Minimum/String : 6.02 dB
compr_Maximum : 6.02
compr_Maximum/String : 6.02 dB
compr_Count : 2
dynrng_Average : 6.02
dynrng_Average/String : 6.02 dB
dynrng_Minimum : 6.02
dynrng_Minimum/String : 6.02 dB
dynrng_Maximum : 6.02
dynrng_Maximum/String : 6.02 dB
dynrng_Count : 2
format_identifier : AC-3
Source : 00000.m2ts
Text
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Duration : 13h 15mn
Source : 00000.m2ts
Menu
00:00:00.000 : Chapter 1
00:05:00.000 : Chapter 2
00:10:00.000 : Chapter 3
13:10:00.000 : Chapter 159
13:15:00.000 : Chapter 160
Right off the bat I see a 13h play time? That can't be right... -
Although many players can play out of spec streams, 8 reference frames is not compatible for avchd or blu-ray - it needs to be re-encoded with compatible settings (6 or fewer for full compatibility at 1280x720 resolution) .
Also, strictly speaking, 1280x720p25 isn't compatible or in the specs (720p25 is usually authored with double pulldown or fake 720p50 by duplicating frames)
There are other settings that are problematic as well - The keyframe interval must be 1sec or less (--keyint 25), unless you use special 2sec GOP settings , and you need to specify other things such as --vbv maxrate and bufsize for buffer compatibility
You might use something like avchdcoder or multiavchd they should "fix" everything for youLast edited by poisondeathray; 9th May 2013 at 17:14.
Thanks, I'll give it a shot. I'm trying to do a non-compliant Blu Ray now that is 13GB. It's been going for an hour now, so we'll see how/if it turns out. I appreciate the help though.
FAT+ troubles with .mkv merged files
By fabpozzi in forum Media Center PC / MediaCentersReplies: 2Last Post: 19th Jan 2011, 10:29 -
mkv to avi troubles.
By joonshik in forum ffmpegX general discussionReplies: 3Last Post: 10th Mar 2010, 17:32 -
MKV conversion troubles
By Alexstarfire in forum Video ConversionReplies: 3Last Post: 7th Mar 2010, 14:10 -
troubles converting BD to MKV w/ RipBot264
By runLoganrun in forum Newbie / General discussionsReplies: 9Last Post: 2nd Dec 2008, 05:20 -
troubles with MKV/OGM to MP4
By ironmaidens in forum Video ConversionReplies: 6Last Post: 23rd Aug 2008, 13:18
