Hi at all!
I've problem to burn some BD with the same structure: not only BDMV and CERTIFICATE but also
PS3_UPDATE,
PS3_VPRM,
PS3_DISC.SFB
With this structure in my Panasonic DMP-BD 60 don't work and also Total Media Player is not able to play it.
The movies are for example Jerry Maguire, I still know what you did last summer, Maximum risk.
I burned the disc with ImgBurn.
Many thanks in advance and sorry for my poor english (I'm italian)
Sounds like you are burning NOT just a single ISO discimage, but rather a series of folders & files. If that is so, my guess is that you've already done the damage, where things that should have linked up in a certain order will now no longer do so.
Obviously, those 3 folders/files are all having to do with PS3 info (probably firmware updates). If they were meant for FW updates, you ought to be doing them via the internet anyway, so these would be superfluous and can be removed.
The removal of them will, in all likelihood, make it possible for ImgBurn to correctly identify the folder structure as once again a BDMV-type disc and will allow it to correctly burn & be successfully played.
AVCHD vs. Blu ray structure, what's the difference?
By jbitakis in forum Authoring (Blu-ray)Replies: 12Last Post: 29th Apr 2016, 07:33 -
Blu-ray remux (.mkv) to Blu-ray structure again ?? how
By Trigarr in forum Authoring (Blu-ray)Replies: 1Last Post: 20th Oct 2011, 08:44 -
H.264 back to blu-ray structure?
By jlm86 in forum Blu-ray RippingReplies: 8Last Post: 21st Feb 2011, 07:19 -
minimum blu-ray folder structure
By tommyjw in forum Newbie / General discussionsReplies: 5Last Post: 12th Aug 2010, 20:51 -
Blu-Ray T.V. Folder Structure & WMC
By carlos28355 in forum Blu-ray RippingReplies: 0Last Post: 3rd Jun 2010, 14:09
