i have a swann mini sports cam which saves to SD. some tines no matter how charged it is it seems to randomly turn off. normily i will just delete the corrupt .AVI file. but today i got some great recording that are part of the "corrupt" file. i know there is data because its file size is 1.3gbs. i believe only a few seconds before i went to turn it off, it did on its own and dint finalize the .avi. ive tried using a few fixers but non seem to work any help would be greatly appreciated
	Hi cmy310,
 You could try (if not done yet) to open the avi file using VLC. It is able to recreate the indexing inside the avi file making it playable. If that does not work then you could diagnose the file using MP4repair.org. Diagnose is free and it's done in your browser, meaning that nothing is installed on your computer. Best of luck!
 --Fire
  Trying to Fix a Huge Corrupt .avi File!By LPrime in forum Video ConversionReplies: 37Last Post: 15th Aug 2014, 23:01
  Corrupt DV Avi fileBy Briansquest in forum Video ConversionReplies: 2Last Post: 15th Jul 2010, 13:01
  Corrupt AVI fileBy wahwill in forum RestorationReplies: 8Last Post: 9th Feb 2010, 00:19
  corrupt AVI files after file recoveryBy sturmie in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 25th Apr 2009, 21:02
  .avi file cannot be repaired - need to remove bad/corrupt framesBy realtechtalk in forum Video ConversionReplies: 0Last Post: 7th Sep 2008, 13:27
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
