Hi there newbie with TMPgenc here so if u have to dumb it down for me feel free yaMy problem is this
I record off antenna to my HTPC a DVB-T channel in 1080i which uses use MPEG4/AVC compression. The original recordings are in .TS files. I then use TMPgenc to cut out the adverts and re-encode to MP4/720p. The first few times i did so things went ok but recently the encoding freezes at just 4-6% and i have no idea how to troubleshoot this![]()
Tried reinstall it?
Or maybe upgrade to tmpgenc video mastering works 5 or try the trial.
Or try some free alternative like video to video converter, under tools can you cut and then reconvert to any format. Or freemake video converter, use the scissor to cut. Or avidemux 6 might work.
Need to figure out portable option for recorded programs
By Sporttster in forum Media Center PC / MediaCentersReplies: 0Last Post: 28th Jun 2011, 19:12 -
Coverting recorded TS or MPEG recorded from DVB card to XVid Avi...
By MohamedYousri in forum Newbie / General discussionsReplies: 4Last Post: 7th Nov 2010, 16:38 -
new recorded dvd can not be played or recorded on after the recording is do
By dlaleh1 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 24th Jan 2010, 23:06 -
Problem capturing audio with most programs, any fixes? + Lagless programs?
By fgsfdsyo in forum Capturing and VCRReplies: 5Last Post: 15th Oct 2009, 17:51 -
TMPGEnc Issues.........
By RKelly in forum Authoring (DVD)Replies: 5Last Post: 19th Jan 2009, 07:15
My problem is this
