Is there some kind of software that shows which music file is technically higher quality (higher bit rate, fro example)? I have 2 FLAC files of the same song and they are similar but not the exact size. I'm suspicious that perhaps one of the file was converted from a lower quality to FLAC for the sake of trying to provide lossless music.
Thanks.
Results 1 to 9 of 9
Nope, you have to listen to it and/or examine waveforms
Flac can have different compression levels (0-8) and encoding settings, so the bitrate doesn't necessarily indicate much
And nothing will tell you what has been done to the audio before the flac stage (maybe some dithering noise applied, lossy encoding) -
A poorly encoded music can be encoded to flac so media info will not help.
That still wont tell you if the sound is good since any type of crap in the wave length of low,medium and high bands can't be heard.
There are actually people who will convert mp3 or some other lossy codec to flac. That could definitely account for differences in file size. I can't see a good reason for anyone doing that but it happens. Frankly it sounds idiotic to me.
For the last decade major labels have been taking perfectly decent older recordings and remastering them by compressing the hell out of them and cranking up the highs mercilessly. I wouldn't touch any of them with a 10 foot pole. They're unlistenable to me. So I guess there's a lot of idiocy out there. Google "loudness wars".
Above all, though, as mentioned, mediainfo will say absolutely nothing about the sound quality. A crap recording will sound bad in 24/192 flac. And the better audio system you play it through the worse it'll sound.
Problem listening super audio CD
By 1234567 in forum AudioReplies: 17Last Post: 22nd Nov 2011, 18:09 -
Help... tired of listening to encoded audio
By pixeltweek in forum AudioReplies: 1Last Post: 18th Aug 2010, 03:31 -
The best of the best headphones for noise canceling and listening to music?
By codered01 in forum Off topicReplies: 0Last Post: 12th Jul 2009, 21:51 -
Clicking noise while listening to music on CD-ROM
By WishMaker in forum ComputerReplies: 6Last Post: 25th Jul 2008, 02:52 -
AVI File from images and voice/music file
By EwanG in forum Newbie / General discussionsReplies: 21Last Post: 19th May 2008, 18:04
