Hi,
I have installed VideoStudio X5 on a home desktop running Windows 7 Home Premium x64 with italian as default language.
During setup of VS X5 I selected italian but at the end when I run the prog I discovered that it was installed in a mixture of italian/english language (e.g. the 4 Menu headings in the Project screen are written in italian while the underlying topics are all listed in english; and so other topics and functions).
I contacted Corel support but they were of no help. They only suggested to check that setting of : “Current language for non Unicode programs” was settled into italian language.I tried other ways to install the program and I noticed that:1. if I install VideoStudio X5 on an other pc running Windows 7 x32, the installation concludes with the program fully in italian;2. if I install VideoStudio X3 on my pc with Win 7 x64, here again the installation concludes with the program fully in italian.I would like to have VS X5 in italian on my pc with Win 7 x64. Any advice?
Un-install the program. Delete all the temporary folders that Corel use. Clear all registry settings.
You mention X3. Un-install that as well as above.
Re-install X5
If that does not work, post a topic on Corel's own user forum. -
DB83, many thanks for your prompt reply.
i did what you are suggesting and i did it more than once to no avail - i did more than that: I created a previous image of partition C:\ by Acronis TI, then formatted the partition and installed a fresh Windows 7 x64 with nothing else but the OS, then installed VideoStudio X5 - and there again at the end there was the known mixture of italian/english
. What a strange version for this app: X3 works properly and X5 doesn't unless i revert to Win 7 32bit.
I contacted many times Corel support and user forum for a matter that i consider an unusual bug. Received one single reply to my messages then silence.
Anyway, i like the prog and if i have to use in esperanto so be it.
Ciao. -
The chances are that someone screwed up when creating the language support files.
I would not use esperanto though. Just stick to the Queen's English
Need help on using Corel VideoStudio X2
By natural4862 in forum Video ConversionReplies: 8Last Post: 12th Jun 2011, 06:13 -
Help Needed Regarding 'Corel VideoStudio X2'
By oedipust in forum Newbie / General discussionsReplies: 3Last Post: 22nd Aug 2010, 06:49 -
Corel VideoStudio X3- Snapping
By Meroko in forum EditingReplies: 5Last Post: 24th Jun 2010, 19:21 -
templates for Corel VideoStudio X3?
By wingfan in forum EditingReplies: 2Last Post: 25th Feb 2010, 15:10 -
Corel VideoStudio 12
By netmask56 in forum EditingReplies: 4Last Post: 20th Nov 2009, 01:25
