Hello.
I record my footage using DXTory using the Ut RGB Codec. Plays fine in Windows Media Player. Looks fine when I edit in Premiere Pro even. I render the footage using H.264 in Adobe Media Encoder. I play it in WMP. Colours look very bright. Play it in VLC and they look fine. I upload to Youtube and the colours look fine except the video skips and has dropped and repeated frames.
Results 1 to 15 of 15
So it's a h.264 AME problem, not UT video Codec problem ? Since your problems occur after encoding using h.264 in AME ?
WMP is a crapshoot, if you have it configured differently you might playback problems . How does it look in other players like MPCHC, SMplayer or PotPlayer ?
For the youtube issue, is it a flash playback isssue ? Download the video from youtube and play it locally with VLC - how smooth is the playback ? -
I can't reproduce the frame skipping. But I can reproduced the bad colours.
MediaInfo report on the Lossless File the encoded file and the redownloaded.
Appears to have a colorspace conversion to YUV
http://pastie.org/7816232 -
You encoded h.264 with AME (AME doesn't support RGB with h.264) . It's pointless anyway because youtube will convert it to YUV when it re-encodes anyways (even if you uploaded an RGB format it will be converted to YUV)
Where are the bad colors? only with WMP ? The answer is simple, either ditch WMP or configure your directshow codecs until you fix it -
What's wrong with your colors? Post before and after shots or sample videos. Maybe you have a rec.601 vs rec.709 problem (slight shift in colors, most noticeable in reds and greens).
https://forum.videohelp.com/threads/329866-incorrect-collor-display-in-video-playback?p...=1#post2045830
Or a rec vs PC matrix problem (contrast changes, most noticeable in black level).
https://forum.videohelp.com/threads/296961-TV-Safe-Colors?p=1812396&viewfull=1#post1812396
YUV 4:2:0 encodes colors at half the resolution of the greyscale image. So a 1920x1080 video has a 1920x1080 grayscale component and two 960x540 color components. So colors are blurry compared to RGB 4:4:4.
https://forum.videohelp.com/threads/294144-Viewing-tests-and-sample-files?p=1792760&vie...=1#post1792760Last edited by jagabo; 7th May 2013 at 22:35.
Adobe Premiere Pro CS 5.5 YouTube Export Project II
By Innomen in forum Newbie / General discussionsReplies: 0Last Post: 28th Jun 2012, 09:57 -
Adobe Premiere Pro CS 5.5 YouTube Export Project.
By Innomen in forum Newbie / General discussionsReplies: 2Last Post: 28th Jun 2012, 01:13 -
What codec did Adobe Premiere Pro originally use, and...
By Cyrax9 in forum MacReplies: 1Last Post: 4th Sep 2010, 15:17 -
Adobe Premiere Pro: I used DV footage and Photoshop stills - how to export?
By neckneck in forum EditingReplies: 12Last Post: 20th Dec 2009, 15:29 -
Premiere pro 2.0 export DVD problem
By meekochan in forum Video ConversionReplies: 3Last Post: 21st Nov 2008, 16:55
