I am using Dazzle to capture old home videos off of a Samsung VHS player. I have been able to do a couple of videos so far but I have run into an issue I have been unable to solve.
Some of my videos have "Hi Fi" that appears on the screen and as soon as it does, all I get is white noise for audio. The video still plays and looks as good as one can expect from VHS format, but the audio just sounds like you tried to tune in a channel on your TV that has no signal.
Any idea what I am dealing with here?
Thanks,
CF
Results 1 to 12 of 12
Check the audio settings on the VCR, you need to have it set to both or at least change it to HIFI for those tapes that need it.
Perhaps you should list the model of the Samsung VCR. If it's extremely old or extremely cheaply made I suppose it might not understand HiFi audio at all. Someone might be able to tell from the model number.
Nic2k4, that is what I was afraid of. Now time to tear up the house trying to find that old remote. Jman, it's a DVD/VCR combo and not that old. I was more afraid that Dazzle wouldn't be able to handle the audio itself or that it was an issue with it being connected by USB or somesuch.
Are you too lazy or too stupid to look up the model number?
Either way, I'm done here. -
The best solution would be to find the remote and see if you can select the audio yourself....or DE-select "Hi Fi" audio. Home movies are not Hi-Fi anyway.
I've come across several tapes that my Philips/JVC S-VHS machine chokes on. It does almost exactly what you are describing....it gets confused and switches between HiFi and Normal and the difference is dramatic. My only solution was to manually set it on "Normal" audio.
dazzle record from tv?
By tomsta79 in forum Capturing and VCRReplies: 44Last Post: 29th Sep 2012, 04:28 -
Other products like the dazzle?
By darklink502 in forum Video Streaming DownloadingReplies: 3Last Post: 19th Mar 2012, 22:47 -
Pinnacle Dazzle. Need help!
By s3r19lk1ll3r in forum Video Streaming DownloadingReplies: 3Last Post: 7th Oct 2010, 16:11 -
Video to Dazzle and Tv
By fellixombc in forum Capturing and VCRReplies: 1Last Post: 6th Jul 2010, 16:52 -
hd tv using dazzle
By zookeeper525 in forum Capturing and VCRReplies: 12Last Post: 11th Apr 2009, 23:14
