I am using Vegas Movie Studio Platinum 9. I was looking at Movie Studio Platinum 12 and there is just enough info there on OS requirements to lead me to ask... Will Movie Studio Platinum 12 work on XP SP3?
	Gary
 Will Fly for Food
	No!!
 ClaudioMinimum system requirements
 - Microsoft® Windows Vista® 32-bit or 64-bit SP2, Windows® 7 32-bit or 64-bit, Windows® 8 32-bit or 64-bit operating system
- 2 GHz processor (multicore or multiprocessor CPU recommended for HD or stereoscopic 3D)
- 500 MB hard-disk space for program installation
- 2 GB RAM (4 GB recommended)
- IEEE-1394DV card (for DV capture and print-to-tape)
- USB 2.0 connection (for importing from AVCHD, XDCAM EX, NXCAM, or DVD camcorders)
- 512 MB GPU memory
- NVIDIA, INTEL, or AMD GPU:NVIDIA
 Requires a CUDA-enabled GPU and driver 270.xx or later.- GeForce GPUs: GeForce GTX 4xx Series or higher (or GeForce GT 2xx Series or higher with driver 285.62 or later).
- Quadro GPUs: Quadro 600 or higher (or Quadro FX 1700 or higher with driver 285.62 or later).
 AMD/ATI
 Requires an OpenCL-enabled GPU and Catalyst driver 11.7 or later with a Radeon HD 57xx or higher GPU. If using a FirePro GPU, FirePro unified driver 8.85 or later is required.
 INTEL
 Requires an OpenCL-enabled GPU such as HD Graphics 4000.
- Windows-compatible sound card
- DVD-ROM drive (for installation from a DVD only)
- Supported CD-recordable drive (for CD burning only)
- Supported DVD-R/-RW/+R/+RW (for DVD burning only)
- Supported BD-R/-RE drive (for Blu-ray Disc™ burning only)
- Microsoft .NET Framework 3.5 SP1 (included on application disc)
- Apple® QuickTime® 7.1.6 or later for reading and writing QuickTime files
- Internet Connection (for Gracenote MusicID Service)
	Minimum system requirements for Movie Studio Platinum 12: Microsoft® Windows Vista® 32-bit or 64-bit SP2, Windows® 7 32-bit or 64-bit, or Windows® 8 32-bit or 64-bit operating system So...it looks like the answer is No.
  Vegas, Win 7, and HuffyuvBy AaronMoorhead in forum EditingReplies: 8Last Post: 28th Apr 2013, 16:45
  Vegas 10 or upgrade to 11?By lordhutt in forum Newbie / General discussionsReplies: 11Last Post: 8th Aug 2012, 12:01
  Suggestions before I upgrade my wife's laptop to Win 7By freebird73717 in forum ComputerReplies: 16Last Post: 12th Feb 2010, 14:41
  Hello..been a long time-Can I upgrade from vegas 5.0 and DVD arch 2.0 to Vegas Pro 9By arcorob in forum Newbie / General discussionsReplies: 6Last Post: 1st Feb 2010, 21:31
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
