Hi Friends,
This time I am again here for some help; I bought a DVD with much expectation regarding the quality.
I was waiting for ripping the DVD; but its my bad luck as the video quality is worst;
I have attached .m2v file.
Please friends, help me out; Please provide with proper filters so that I can get excellent quality of this movie.
N.B.: I am using Megui; create AVS file, then rip dvds.
Thanks in advance...
Results 1 to 12 of 12
The quality will always suck. Take your pick. I usually use Limited Sharpen Faster:
http://avisynth.org/mediawiki/External_filters#Sharpeners -
Using QTGMNC and sRestore I get 25fsp with no frame blending, but the color and levels are a mess. Darks are crushed and murky, highlights blown out. Real problem. Needs some denoising and resize if you want PAL DVD.
@sanlyn, thanks for your valuable comments. I have also understood the condition of the DVD; now your detailed explanation added a extra to this.
Now in this situation, I wanna get a standard picture quality with more brightness & contrast so that this time I can get relief.
Well...there are frame problems. I used stab() to calm most of the frame hopping, but you still see some shudder, bent forms, objects twisting, etc. Actually not much noise. Oversharpening low-bitrate video makes it look extremely odd, especially on TV: plastic, easy to get halos, etc. The problem is that low bitrate has no detail to begin with. All one can do is over-enhance edges, which looks strange because the objects have no "inner" detail.
Many severe color problems. Someone wrecked the basic colorspace. Colors will never look quite correct. And it appears auto-color gadgets were used in the process -- in the source you can see color and levels change when the camera moves. The PAL mpg attached also had some image repairs (source is on the left, sample effort mpg is on the right):
RemoveSpots() cleaned many spots and dots, such as this white cherry bomb on the left-hand border:
[Attachment 17679 - Click to enlarge]
ReplaceFramesMC used on 12 frames in this sample, for multiple scratch marks, bombs, and dots:
[Attachment 17680 - Click to enlarge]
And manual patches, as to patch in part of a clean section from another frame (not always possible):
[Attachment 17681 - Click to enlarge]
It would take many weeks of constant effort to fix this video -- possibly months. I'd look for a clean copy of the movie. The MPG sample below was encoded as progressive PAL, almost twice the size of the low bitrate source. Increasing bitrate can't "improve" low bitrate sources, it just helps prevent worsening. There is still some stutter and odd motion now and then, mainly because the party that made the source did their best to ruin it.Last edited by sanlyn; 28th Mar 2014 at 18:38.
You should learn to look at video more closely. Your sample clip is already too bright and has too wide a range of contrast. That's one reason why it looks so strange, and why it is difficult to correct. It doesn't help that the original colorspace has been damaged somehow.
Video Enhancer-VirtualDub like program-to enhance video-when upsizing!
By Milardo in forum EditingReplies: 43Last Post: 9th Apr 2015, 21:39 -
Video enhance
By Videographer in forum Newbie / General discussionsReplies: 0Last Post: 28th Aug 2011, 16:10 -
DVD to HD (resize and enhance image quality)
By SB4 in forum RestorationReplies: 12Last Post: 14th Dec 2010, 16:54 -
Enhance Video Software
By Teac23 in forum RestorationReplies: 17Last Post: 3rd Mar 2009, 10:09 -
How to Enhance Video Quality
By timequest in forum Newbie / General discussionsReplies: 2Last Post: 6th Oct 2008, 17:12
