I see on their page a product feature comparison grid. Are the two tiers "the same" in terms of User Interface, workflow, etc. and I just pick the point that has the features I care about?
Or, is it like Adobe's products where the consumer end is really watered down and has a somewhat different UI?
Go with Vegas. Pinnacle sucks. Always has.
Adobe is watered down? Are you comparing Vegas/Adobe in their $100 dumbed-down average consumer editions, or the Pro editions? In the cheaper packages, both are watered down. In the Pro Editions, Vegas Pro is a "sort of" (but not cheap) version of a combo Adobe Premiere Pro and After Effects Pro, but with just a subset of the features from both. For final encoding, there are better encoders than any of these apps, but they suffice for most users.
Your mileage might vary. Depends on how advanced you want to get. Pinnacle won't take you very far.Last edited by sanlyn; 28th Mar 2014 at 18:39.
I don't know what you are referring to by Pinnacle.
By watered-down, I mean regular $$$$ Adobe vs $ Adobe "Elements" version. I'm wondering if the pro/consumer split implied by the different names (Vegas vs Movie Studio) means that there are UI/workflow differences that are more substantial than what their comparison matrix shows (e.g. number of tracks, effects included, etc.)
Based on the produce matrix, I chose the $130 (list price) version and started the demo. But I can't figure out how to use a different encoder with it, as I explained on another thread. I wonder if that's another feature difference, or a demo restriction, or what? -
Oh, that "Movie Studio" (sometime people use that as a generic term for some Pinnacle stuff. Sorry). Vegas Movie Studio is no more watered down than Adobe Elements. Since more advanced apps aren't what you're after, stick with what you've chosen.
Vegas Movie Studio HD Platinum 10
By jjblackisback in forum SubtitleReplies: 3Last Post: 26th Apr 2011, 20:28 -
vegas movie studio
By pgo in forum Video Streaming DownloadingReplies: 1Last Post: 7th Jan 2010, 18:06 -
Will Vegas Movie Studio 9 do it?
By ccm in forum Newbie / General discussionsReplies: 2Last Post: 3rd Aug 2009, 13:41 -
What is the difference between Vegas Pro and Vegas movie studio platinum
By jbitakis in forum Newbie / General discussionsReplies: 4Last Post: 18th Feb 2009, 00:41 -
I cannot start Vegas Movie Studio 9.
By scaperat in forum EditingReplies: 2Last Post: 11th Aug 2008, 12:46
