I've been trying to use tsMuxeR to combine my .mkv movie files with .srt subs to play on the home theater system via BD. I start out by dropping the .mkv's and .srts into the interface, changing the level to 4.1 (if not there already), specifying the output path, and selecting the "Blu-ray disk" radio button. I then click start muxing. From there, I use ImgBurn to burn the resulting BDMC and CERTIFICATE folders onto a 25GB Blu-ray disk.
I've been having <50% success rate using this method. 90% of the time I have issues here's what happens. I get a "successful" burn, pop the Blu-Ray into the player, and all that I get is sound. No videos, no subs, nothing except sound. Most of the time it's just black. Occasionally, the Blu-Ray player interface background will stay up while the sound plays.
When I pop the disk back into my computer it reads it just fine. I can even play it from there, however if I look into the folder structure the file type it is M2TS. I suspect that this is the reason I'm not getting video but am not knowledgeable enough to be certain. I am, however, 100% sure that I'm selecting the "Blu-Ray" options vs. the "M2TS" radio in tsMuxeR.
Does anybody know what's going on or how I can fix it? When I select a Blu-Ray burn should it be producing M2TS files in the folder structure at all? I'd appreciate any info or tips.
Your MKVs (if you didn't make them yourself) may have been cropped. To make a Blu-Ray from MKV, the resolution must be Blu-Ray compliant. (See what is Blu-Ray, upper left).
Use MediaInfo to find the file attributes. When you find one that's not compliant, you have no choice but to add the black bars back by re-encoding. With uncropMKV, for example. Or use AVCHDCoder, which if memory serves, can take non-compliant MKVs and output BD/AVCHD structure.
Anyway, that's what comes to mind first, and would certainly cause your problem. And it's easy to check, so rule that in or out first.
Good luck.Pull! Bang! Darn! -
Thanks for that info! I'll give it a shot tomorrow first thing. Just to make sure I understand the process correctly, where in the process would I add the black bars? Is that before or after muxing? I'm assuming that's done before, to the original .mkv without the subs muxed in?
Like tsmuxer...
By fits79 in forum Video ConversionReplies: 12Last Post: 31st Dec 2012, 10:04 -
TSMuxer crashing error code -3 TSMuxer GUI
By petermg in forum Authoring (Blu-ray)Replies: 2Last Post: 30th Nov 2012, 16:21 -
tsMuxeR issue???
By romm2002a in forum Blu-ray RippingReplies: 1Last Post: 25th May 2011, 03:39 -
downconverting HD Audio in TsMuxer issue
By Modify_inc in forum Blu-ray RippingReplies: 0Last Post: 21st Jul 2009, 11:20 -
Issue with TSMuxer and DTS audio
By ma2kp in forum Video ConversionReplies: 2Last Post: 25th Oct 2008, 14:16
