  1. Hi guys
    My DVD/USB player only supports files that I convert from whatever file type they are to AVI MPEG4 using Total Video Converter. No other AVI codecs work. Unfortunately, I can no longer use this program, since it simply refuses to progress the conversions I attempt nowadays. I have no idea why this is...
    Any other conversion programs you can choose the AVI codec you prefer, particularly MPEG4?
    Kind regards,
    JvZ
  2. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Virtualdub...
    Claudio
    Mar 2011
    Nova Scotia, Canada
  4. I agree about the programas mentioned before, but for a quick and simple conversion to MPEG 4 (xvid) that will play easily in most USB/DVD players I use Freemake Video Converter (If you decide to try it, make sure to uncheck the tool bars or other apps it suggests while installing)
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    Or xvid4psp 5 and use the avi hardware profile.
    Or video to video converter, xmedia recode, winff. Try use avi with xvid.
    Aug 2007
    Isle of Man
    MediaCoder might be worth a look too.
    Cheers,
    Francois
