Is it core that I keep it in? Trying to avoid the encoding process to figure it out.
Just use copy audio if you want to keep it EXACTLY as it is.
Otherwise the dts core will be the standard def audio not the hd dts.
Frankly converting the audio to ac3 at 640kpbs should be more than adequate for most people and save you quite a bit of space at the same time.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
The space I don't mind. At least right now. I have plenty of it at the moment and probably won't be filling it up any time soon as I'm no longer adding movies to my server like I used to.
But don't I have to select an audio option before I get to copy? Before I get to there, there is usually a radio button to switch between core, wave and flacLast edited by AndyD; 5th May 2013 at 09:01.
Originally Posted by andyd
As I said I don't know what the new version is like so it might be layed out slightly differently. It should still have a copy audio option however.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
So I just ripped Girl with a Dragon Tattoo. Right before demuxing is a radio button to switch between the wav / flac / core options. After, that it's what you're referring - copy stream
I encoded the movie and receiver / media info is showing DTS
Could it be that Ripbot does not touch the DTS MA track or is this what I should expect for DTS MA
Convert MKV to AVI keeping DTS track intact
By samatdell in forum Video ConversionReplies: 5Last Post: 18th Oct 2012, 10:56 -
Ripbot and keeping dts-hd track issue
By cburbs in forum Blu-ray RippingReplies: 1Last Post: 17th Feb 2012, 15:21 -
Rebuilding a DVD9 to DVD5 keeping DTS intact
By zoomie in forum Newbie / General discussionsReplies: 13Last Post: 6th Jan 2011, 00:37 -
MKV to dvd while keeping the dts audio intact
By Loonatik in forum Authoring (DVD)Replies: 13Last Post: 30th Mar 2010, 10:41 -
help gettinng .m2ts with dts to play on ps3 with the dts intact. got close
By jayjay139 in forum Blu-ray RippingReplies: 0Last Post: 12th Mar 2010, 12:10
