I see. That makes sense. I take it there isn't any readily available method of asking a plugin to just interpolate X even / odd field (if there would be a method of arbitrarily defining this such as counting from the top) and disregard altering the rest, and inject the result. That way I could just call that function in a second pass over every frame that needs it. Though if that existed in such an easy way, it'd probably already be documented...somewhere.
I didn't know that bouncing was a normal thing though, so this is good to know.
Results 31 to 40 of 40
You could overlay the top line with picture information onto the frame, shift up by one scanline. Ie, if line 4 is black, shift line 5 up to cover it. That's no perfect but maybe a less objectionable than the bob bounce.
Edit: Removed what I wrote as even in the result I uploaded earlier I see that slight bobbing. I wouldn't worry about it myself. I consider that to be very minor.
Just a matter of curiosity, if maybe there's a better approach to this. There are places I'll frequently run into segments that break the telecine pattern by too large a margin (usually at a scene change leaving an orphaned field between the two). But I still have to drop a frame in that 5 frame cycle, making it fall to a matter of dropping the one that won't show any, or the least skips in motion.
I tend to be a perfectionist about these things. I'm not certain if TDecimate's mkv timecodes function would suffice for this, but it doesn't seem like fieldhint's override files works with TFM either way.
Is there any other approach for this to get around dropping these frames?
As a sidenote. I thought about just rendering that series of frames separately and splicing it with the other sections, but I can't quite wrap my mind around what frame rate I'd have that portion run at, at that point. I'd think it'd simply be 23.976 + 1 more frame in that interval, making it 24.976. But I suppose that just doesn't seem to account for the fractional value that's there to begin with, hence the uncertainty. Though I guess frame rate is really just a simplified way of expressing the timestamps of any given frames in the interval of one second, so it does make sense from that angle.Last edited by Acetyl; 7th Aug 2013 at 14:04.
You would have to specify a manual overrides file if you can't adjust the other settings to keep or drop what you want
That math would only be true if that segment was 1 second long...As a sidenote. I thought about just rendering that series of frames separately and splicing it with the other sections, but I can't quite wrap my mind around what frame rate I'd have that portion run at, at that point. I'd think it'd simply be 23.976 + 1 more frame in that interval, making it 24.976. But I suppose that just doesn't seem to account for the fractional value that's there to begin with, hence the uncertainty. Though I guess frame rate is really just a simplified way of expressing the timestamps of any given frames in the interval of one second, so it does make sense from that angle.
If you're doing this manually it's usually easier to use v1 timecodes, where only the deviations or change in frame rate over a certain frame range is expressed, otherwise fps is assumed to be a base value -
That's what I'm doing, it still seems to drop frames that aren't in the 5 frame cycle.
I'm using a v1 timecodes file for it anyway (the openings and endings) so it seemed like an appealing option. Would 24.976 for that segment (of 7 frames or so) generate the right frame timings? -
Ok, it's not something I do very frequently . Are you saying it's not paying attention to the overrides ?
If nobody else chimes in, I would suggest asking for help at Doom9 forum. I know there are some people there that do this manual stuff overrides frequently, they would be the ones to ask
You would probably have to post a sample, your script, and your overrides file
That doesn't quite work out over 7 frames, but the only way to be sure is test it out
If my math is right, I think you can figure it out by doing the fraction . e.g. lets say the base rate is 24000/1001 , the normal sequence is 7 frames, but you want to include 8 frames in that section .
24000/1001 * 8/7 =~ 27.401 -
If you specify keeping a frame in an overrides file, one that would have been otherwise dropped, then a different frame will be dropped in that 5-frame cycle.
Since you said this happens mostly at scene changes, then aren't the fields/frames being dropped at the scene changes themselves, so there's no jump or other obvious sign of missing frames?
The best way to 'cover-up' missing frames is with the use of SmartDecimate as the IVTC, as I suggested earlier. In cases such as yours it has the ability to use a bobbed field to 'smooth-over' the movement. -
I see. It isn't ignoring the overrides file entirely, it'll just make a decision to drop 1 if I don't specify in a segment.
Ah, that's interesting... with that equation, regardless of the respective values, it would never move above the original frame rate (in this case 30000/1001)... only in increments between the two. I'll have to try this. -
Stretched duration after IVTC (sync issue: audio drift)
By ARTO65 in forum DVD RippingReplies: 11Last Post: 10th Jun 2010, 19:38 -
IVTC - could someone help?
By Gew in forum Newbie / General discussionsReplies: 51Last Post: 8th Feb 2010, 21:26 -
Why can IVTC not be perfect?
By loekverhees in forum Newbie / General discussionsReplies: 12Last Post: 31st Oct 2009, 17:51 -
Decomb IVTC issue
By iamtehsux in forum DVD RippingReplies: 9Last Post: 1st Mar 2009, 03:48 -
ivtc help
By iamtehsux in forum Newbie / General discussionsReplies: 3Last Post: 20th Dec 2008, 19:58
