Is there a vob cutter that allows you to skip ahead to the part of vob and cut that out without having to watch the whole file? thank you, John![]()
Results 1 to 10 of 10
Is there a piece of freeware that allows batch cutting? That. Actually cuts and save where you tell it to cut? I am using Bob cutter. And video cutter, but they seem to jump ahead! John
Vobs can only be cut on GOP boundaries, roughly every half a second for NTSC. If yours jumps ahead more than that you're using the wrong cutter.
And what good is a batch cutter if you have to tell it where to cut each time? -
It would be nice if the cutter would cut where I tell it do. Is there one that does this? What are GOP Boundaries? John
MPEG2 for DVD doesn't encode each frame completely. Instead, the differences between frames are stored
GOP = group of pictures , it's a method of lowering bandwidth requirements (ie a method of temporal compression)
I frames represent complete pictures, and there is one I frame for each GOP - but P and B frames are only "partial" pictures. GOP boundares occur right before the I-frames
It might look something like IBBPBBPBBPBBIBBP...
You cannot cut on other frames, because they are incomplete by themselves - they rely on information from other frames within that GOP. If you cut in the middle of the GOP, the frames will be corrupted . If you had a stream that was I frame only, then you could cut anywhere , because each frame is complete (e.g. IIIIIIIII)
There are cutters that are frame accurate, and they re-encode the frames within that GOP. They re-make the GOP, thus there is quality loss within that GOP (other segments are passed through untouched). This process is called "smart rendering" - e.g. videoredo, solveigMM video splitter, tmpgenc smart renderer -
Most of these video have a black screen before and after the video I want to cut. Now is there a way to chop the vob file in different places and save the area in between into temporary files? So I can rename them . Would a smart renderer work to cut the file where I want it? Thank you John
Have you even tried any of the programs suggested yet? The original MPEG2Cut I suggested allows you to cut anywhere you like, as long as it's on a GOP boundary. Others, such as the ones pdr mentioned, allow for frame-accurate cutting. They all cost money, though, but they all also allow trial use of the programs.
Looking for AVI cutter
By rocks911 in forum EditingReplies: 2Last Post: 27th Jan 2012, 17:23 -
mkv cutter
By kosoul4 in forum EditingReplies: 5Last Post: 16th Nov 2010, 23:10 -
VCD Cutter
By devilcoelhodog in forum EditingReplies: 0Last Post: 16th Jan 2010, 16:39 -
h.264 ts cutter
By stewart041170 in forum Newbie / General discussionsReplies: 0Last Post: 3rd Jan 2010, 16:06 -
Looking for Mpeg2 Cutter
By 557953 in forum EditingReplies: 6Last Post: 8th Sep 2008, 23:56
