Hi folks,
I use AviDemux Portable, I have several different versions on my laptop ... well I wanted to run an MP4 file from YouTube thru it to re-save it as MP4 again. The reason I do this is because some MP4 files from YouTube Crashes my Netgear EVA9100 Media Player ... and I have Not been able to pinpoint the reason why!?!? But running it thru AviDemux solves my problem.
Anyway, I wanted to run a MP4 file thru AviDemux and I noticed something very Odd thing ... there was No Audio when I was playing back the Video file in AviDemux. I checked the file in VLC and sure enough there is an Audio in the video file and sounds just fine.
I tried many MP4 files with different AviDemux Versions that I have on my laptop.
The only versions that had Audio were versions "AVIDemux 2.5 r7200 Portable" and "AVIDemux 2.5.6-1 r7716 Portable".
Versions "AVIDemux 2.6 r7719 Portable" and above including latest Beta "AVIDemux 2.6 r8494 Portable" can NOT play the Audio ... video plays just fine.
Q1: Has anyone run into this problem? And how can I fix it?
Q2: Is there another program that can replace AviDemux with Similar Functionality?
Thanks!
G!![]()
You can try remux/resave with it mp4box or a gui for it like mymp4boxgui, add the mp4 and make a new mp4.
Avidemux aspect ratio question [from newbie to Avidemux]
By ANOther1676 in forum EditingReplies: 1Last Post: 20th Jan 2012, 20:07 -
Odd Audio Sync Problem
By Startropic1 in forum Video ConversionReplies: 0Last Post: 13th Aug 2010, 00:07 -
Hauppauge 150: Another Odd Problem
By Tom Saurus in forum Capturing and VCRReplies: 0Last Post: 12th Jun 2010, 11:22 -
Odd ac3 sync problem
By mayancastle in forum DVD RippingReplies: 7Last Post: 24th Jun 2009, 21:34 -
Odd problems with Avidemux 2.4, not saving it as .mp4....
By Kaminoshi in forum Video ConversionReplies: 9Last Post: 12th Jul 2008, 11:11
