Hi Everyone ... I'm looking for a recommendation for a microphone for audio recording. Specifically, I'm looking to record a narration for a video (to be posted on YouTube). My budget isn't enormous, but I do want quality. Note, I don't need a headset / mic combo since this isn't for gaming.
Because I'm so efficient, I first started with the mike that was on my camera and never looked back. I'm still amazed how good it is.
I'm sure others will have recommendations - just thought I'd throw that out there to start with. -
Sorry to tell you this zoobie, but while that may be "efficient", it is not optimal. Rarely is the method used for getting optimal video ALSO the optimal audio method.
@jellyfish, please be specific: what's your actual budget? your workflow & current equipment/toolset? your recording environment?
Scott -
Maybe something like this?
http://www.bhphotovideo.com/c/product/588893-REG/Behringer_C_1U_C_1U_Condenser_Microphone_with.html
http://www.bhphotovideo.com/c/product/751978-REG/Audio_Technica_ATR2500_USB_ATR2500_US...icrophone.html
or this:
http://www.bhphotovideo.com/c/product/598775-REG/Samson_SAGOMICS_Go_Mic_USB.html
with any of these youŽll need also a pop filter:
http://www.bhphotovideo.com/c/product/904756-REG/Nady_MPF_7_BLACK_MPF_7_MIC_POP_FILTER.html
As they are quite sensitive, youŽll want to place them as far from your computer as posible (and facing AWAY from it) to avoid picking up the PCŽs fan noise. -
Buy a mike stand w/ crane arm attachment & windscreen/pop-filter = ~$25.
Buy a Cardioid Condenser mike, for your case, you might be able to do with a USB-based one: Audio-Technica AT2020USB = $95. It has built-in (from USB) "phantom" powersupply, and analog-to-digital converter on-board, so it's fairly low noise (not fully-professional low noise @-120dB, but better than PC users are used to - @-75dB).
Also get some foam padding or blankets to ~surround near the area where you'll be recording.
Maybe get a copy stand so you don't have to hold your notes while you read the narration. Better to stand while reading (opens up the diaphragm).
Good places to check out = Sweetwater.com, B&Hphoto, Markertek,TAIaudio.
<edit>julitomg got back to you first. Looks like similar ideas. I agree, PC fan & house A/C (and maybe other household appliances) will be your largest sources of noise. -
Awesome ... thx julitomg and Scott ... I'll definitely look into these recommendations
Really looking forward to researching into this. Thanks again!
what microphone do i need?
By dakota5369 in forum Newbie / General discussionsReplies: 0Last Post: 23rd Apr 2012, 01:03 -
Need recommendation-Beginner-Video-Editing softwater/computer
By TeaOlive in forum Newbie / General discussionsReplies: 10Last Post: 20th Jun 2010, 13:06 -
Looking for a Microphone...
By duderdude2 in forum AudioReplies: 6Last Post: 2nd Feb 2010, 15:35 -
Request for recommendation of a good wireless Microphone
By rfdillon in forum Newbie / General discussionsReplies: 0Last Post: 25th Jul 2008, 13:52
