Hello
Using ffmpeg.exe N-52045-g694fa00 "built on Apr 12 2013 16:54:51 with gcc 4.8.0 (GCC)", I followed tutorials (here and here) about how to use ffmpeg to replace the audio track in an FLV file, but I couldn't get this to work.
Here's the original FLV...
...and the audio track edited in Audacity:Code:Input #0, flv, from 'input.full.flv': Metadata: starttime : 0 totalduration : 608 totaldatarate : 676 bytelength : 51367355 canseekontime : true sourcedata : BD075FE65HH1367193223014001 purl : pmsg : Duration: 00:10:07.84, start: 0.000000, bitrate: 676 kb/s Stream #0:0: Video: h264 (Main), yuv420p, 640x360, 551 kb/s, 29.97 tbr, 1k tbn, 59.94 tbc Stream #0:1: Audio: aac, 44100 Hz, stereo, fltp, 131 kb/s
First, I tried demuxing the video stream:Code:Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'input.audio.edited.m4a': Metadata: major_brand : M4A minor_version : 512 compatible_brands: isomiso2 creation_time : 1970-01-01 00:00:00 encoder : Lavf52.64.2 Duration: 00:10:07.95, start: 0.000000, bitrate: 154 kb/s Stream #0:0(und): Audio: aac (mp4a / 0x6134706D), 44100 Hz, stereo, fltp, 152 kb/s Metadata: creation_time : 1970-01-01 00:00:00 handler_name : SoundHandler
While the original FLV file is 10:07, VLC says the extracted H264 video file is now 2:02:00 long, and doesn't play.Code:ffmpeg.exe -i input.flv -vcodec copy -an -f h264 output.h264
Next, I tried simply replacing the audio track with the file edited in Audacity:
It seems like the data is re-encoded, and the audio hasn't changed anyway.Code:ffmpeg.exe -i input.flv -i input.audio.edited.m4a test.flv
What is the right command to use to simply replace the audio track with with no re-encoding (transcoding)?
Thank you.
You could try this...
Don't know if you still get issues with the remuxed duration?Code:ffmpeg.exe -i input.flv -i input.audio.edited.m4a -vcodec copy -acodec copy -map 0:0 -map 1:0 test.flv
I found a work-around by extracting the video + audio streams using FLV Extract, but I still wonder why ffmpeg fails extracting the H264 stream, though.
Add an audio track or replace the audio track of an AVI
By abrafax in forum Newbie / General discussionsReplies: 9Last Post: 1st Oct 2012, 14:34 -
Replace .MKV Audio with Different Track
By Justron in forum Video ConversionReplies: 2Last Post: 1st Feb 2012, 17:03 -
How do I replace audio track on Mp4?
By unwired in forum EditingReplies: 3Last Post: 24th Jul 2011, 14:53 -
replace audio track in retail DVD
By foolosophy in forum AudioReplies: 7Last Post: 2nd Aug 2008, 18:04 -
Freeware to replace audio track on a video file?
By gastrof in forum Newbie / General discussionsReplies: 2Last Post: 2nd Jun 2008, 21:54
