I would like to render a project from Sony Vegas PRO 12.0. I would like to set the output file to have the preferences that you can read in the text file I attached, it is a Mediainfo export. How could I set these things? When I click Render, I get a list of output formats, but the list is totally a mess for me. When I clcik something, the customization panel doesn't allow to set any kind of option, only a select few. Not like in Xilisoft Video converter, where in the Advanced tab you can just add almost any value to a setting. In Vegas I am unable to find how I could have a baseline mp4 59.94p Full HD 25 mbps CBR. Every format I choose disallow setting one of these options. Which format shall I choose?
You cannot have baseline set with full HD video 25Mbit, you have to set High@L4.2, this is specs. Better to say you set high and 59.940 fps and Vegas (Mainconcept or Sony) will set level 4.2.
Presets in Vegas are mere suggestions, you can customize them, save them, you take Sony encoder, pick any Memory Stick preset, set avc (this is important, you have to start with it) in Custom (instead of memory Stick), now you can choose High, then you change fps , bitrate .... or you pick Blu-Ray stream and again, choose avc instead of Blu Ray- avc, etc...
or you choose MainConcept, some preset and you can change the whole thing ....for example, if you choose Internet profile and modify it, and it gives you trouble, you choose Blu-ray stream and modify it to your needs, sure you can mux your video and audio outside of Vegas (mp4boxgui, mkvmerge), just pick what is going to work (to modify internet preset was giving me some trouble during playback, but not sure if this is one of those Vegas encoder quirks)
sure those encoders have limited settings, nothing fancy
How to render/save video with lossless codecs in Sony Vegas pro 12?
By Stears555 in forum Video ConversionReplies: 12Last Post: 19th Oct 2012, 14:54 -
try to render file with HuffYuv video format on Sony Vegas, please help!!!
By byair74 in forum EditingReplies: 0Last Post: 15th Feb 2012, 04:28 -
Sony Vegas Pro 10 - video/audio out of synch after render
By Acester47 in forum EditingReplies: 4Last Post: 1st Jul 2011, 15:06 -
Sony Vegas 10 problems. Cannot render video (no dvd) and cannot youtube
By KariKnutzen in forum EditingReplies: 6Last Post: 10th Jun 2011, 18:25 -
Best render for 4:3 video using Sony Vegas pro 10 for youtube
By fuzzblaster in forum Video ConversionReplies: 0Last Post: 9th Jan 2011, 14:18
