Hey there,
i'm new to videohelp.com and i'm having a problem like mentioned in the thread title already.
Some days ago i've downloaded some video's in flash format (.flv), however only one file could only be downloaded in mpeg4 format (.mp4) when playing the (mp4) video there is no sound being played.
Don't know for sure what the rootcause is or what i should do to fix... ?
Please HELP, it's greatly appreciated![]()
GEEn_KLASSE![]()
Use the program mediaplayerclassic home cinema to play the file. It has the internal codecs that most files would need to play properly. You shouldn't need to install anything separately.
However you should use mediainfo as suggested to verify what the file uses and make sure you have the codec installed for the future if you plan on getting more files of this type.
Please also note you might have gotten a corrupted file. You could try redownloading it again. Also I am assuming the original file played properly. Otherwise if there is a problem with the source file you will have to look for another version of it somewhere else.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Hi,
thanks for replying , í've downloaded mediainfo as suggest; don't know for sure if the below info is the info you need(?).(also not femiliar with mediainfo)...
General
Complete name
)Dragonball Z Episode 150 Up to Piccolo - YouTube.mp4
Format : dash
Codec ID : dash
File size : 51.2 MiB
Duration : 18mn 1s
Overall bit rate : 397 Kbps
Encoded date : UTC 2013-04-12 07:23:27
Tagged date : UTC 2013-04-12 07:23:27
Video
Format : AVC
Format profile : Main@L3.0
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : avc1
Duration : 18mn 1s
Bit rate mode : Constant
Bit rate : 395 Kbps
Width : 640 pixels
Height : 360 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 24.000 fps
Minimum frame rate : 24.000 fps
Maximum frame rate : 3 000.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.071
Stream size : 50.9 MiB (99%)
The SW is used to download the file is RealPlayer.
Thanks -
Are you sure that's the full summary from MediaInfo: There is no audio in that file to play.
Download it again. Look's like the download was incomplete or the file is corrupt. -
Yes, thats the full summary. i've downloaded it again, but still the same summary. I've compared it with some other files and it's indeed missing.
mp4 files corrupted, missing GOP format settings, any way to fix?
By smca in forum Newbie / General discussionsReplies: 6Last Post: 20th Apr 2013, 19:10 -
MP4 never closed, missing header?
By ETM in forum Capturing and VCRReplies: 5Last Post: 25th Feb 2011, 15:40 -
No Sound from MP4 file
By Alexstarfire in forum AudioReplies: 10Last Post: 18th Aug 2010, 03:59 -
mp4 to flv file I only get sound through the web browser but no picture?
By robbg in forum ffmpegX general discussionReplies: 2Last Post: 21st Mar 2010, 11:04 -
Video track header missing in MP4 file
By MaNuHelp in forum EditingReplies: 6Last Post: 17th Apr 2009, 10:23
